Altair RISE
Nominate Yourself Now!
Please help - can't import Excel sheet in RM 5.3.13
akarpun
I got strange issue with Rapidminer 5.3.0.13 - after creating new local repository, I click ob Import Excel sheet and nothing happend.
Funny enough - on same computer, Rapidminer 5.2.008 is doing without any problems.
Maybe someone solved this mystery ?
I'm on MacOSX 10.6.8, Java ver. 1.6.0_51 from Apple
Thank You in advance
Marco_Boeck
what does the log say? It can be found in user_home/.RapidMiner5/rm.log
Marco
akarpun
2013-09-17 12:51:04 com.rapidminer.RapidMiner performFirstInitialization
INFO: Performing upgrade from version 5.2.008 to version 5.3.013
2013-09-17 12:51:04 com.rapidminer.tools.I18N <clinit>
INFO: Set locale to en.
2013-09-17 12:51:06 com.rapidminer.tools.plugin.Plugin registerPlugins
INFO: Register plugin: Text Processing
INFO: Register plugin: Web Mining
2013-09-17 12:51:08 com.rapidminer.tools.expression.parser.ExpressionParserFactory <clinit>
INFO: Default version of expression parser registered successfully
2013-09-17 12:51:09 com.rapidminer.parameter.ParameterTypePassword decryptPassword
WARNING: Password in XML file looks like unencrypted plain text.
2013-09-17 12:51:10 com.rapidminer.tools.OperatorService init
INFO: Number of registered operator classes: 509; number of registered operator descriptions: 510; number of replacements: 437
2013-09-17 12:51:10 com.rapidminer.tools.jdbc.JDBCProperties <init>
WARNING: Missing database driver class name for ODBC Bridge (e.g. Access)
2013-09-17 12:51:10 com.rapidminer.tools.jdbc.JDBCProperties registerDrivers
INFO: JDBC driver ca.ingres.jdbc.IngresDriver not found. Probably the driver is not installed.
2013-09-17 12:51:12 com.rapidminer.gui.ApplicationPerspectives loadAll
CONFIG: Loading perspectives.
2013-09-17 12:51:12 com.rapid_i.deployment.update.client.UpdateManager checkForUpdates
CONFIG: Ignoring update check. Last update check was on 9/16/13 5:32 PM.
akarpun
Is process different between 5.2 and 5.3 ? I'm quite new to RapidMiner and was about to start learning how to use it, but ...
I do it like this:
After Splash screen, I select New Process,
than In left corner, I choose my local repository,
create folder there
click on it
than click on button with green arrow above and choose Import Excel sheet - and nothing happened.
If I continue to go through options from this drop-down menu - only last 3 things invoke dialogs for import: Access DB Table, Database Table, Binary File
First 3 is not work at all
Please help
Marco_Boeck
I just learned you do need Java 7 for the latest RapidMiner versions. If you do not have access to Java 7, you will need to use RM 5.3.008 I'm afraid, or update your OS Lion.
Marco
akarpun
Thank You for Your help.
Yes, indeed, RapidMiner 5.2.008 working ok with my version of Java.
