Hello Friends!
I am doing a sentiment analysis for my thesis. I am trying to annotate some tweets. Any one has tutorial for the extract sentiment operator?
The problem occured: Error reading Map failed. PLEASE FIX this for me. Thanks a lot!
I have encoded my XML code here:
<process version="6.5.002">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.5.002" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="read_excel" compatibility="6.5.002" expanded="true" height="60" name="Read Excel" width="90" x="45" y="30">
<parameter key="excel_file" value="E:\CC\database\csv\2.26.xls"/>
<list key="annotations"/>
<list key="data_set_meta_data_information"/>
<operator activated="true" class="nominal_to_text" compatibility="6.5.002" expanded="true" height="76" name="Nominal to Text" width="90" x="179" y="30">
<parameter key="attribute_filter_type" value="no_missing_values"/>
<operator activated="true" class="text:process_document_from_data" compatibility="6.5.000" expanded="true" height="76" name="Process Documents from Data" width="90" x="380" y="30">
<parameter key="keep_text" value="true"/>
<list key="specify_weights"/>
<operator activated="true" class="text:tokenize" compatibility="6.5.000" expanded="true" height="60" name="Tokenize" width="90" x="45" y="30"/>
<operator activated="true" class="text:transform_cases" compatibility="6.5.000" expanded="true" height="60" name="Transform Cases" width="90" x="179" y="30"/>
<operator activated="true" class="text:filter_by_length" compatibility="6.5.000" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="313" y="30">
<parameter key="min_chars" value="2"/>
<operator activated="true" class="text:generate_n_grams_terms" compatibility="6.5.000" expanded="true" height="60" name="Generate n-Grams (Terms)" width="90" x="447" y="30"/>
<operator activated="true" class="wordnet:open_wordnet_dictionary" compatibility="5.3.000" expanded="true" height="60" name="Open WordNet Dictionary" width="90" x="45" y="120">
<parameter key="directory" value="E:\CC\database\csv\WordNet-3.0\dict"/>
<operator activated="true" class="wordnet:stem_wordnet" compatibility="5.3.000" expanded="true" height="76" name="Stem (WordNet)" width="90" x="179" y="120"/>
<operator activated="true" class="wordnet:find_sentiment_wordnet" compatibility="5.3.000" expanded="true" height="76" name="Extract Sentiment (English)" width="90" x="313" y="120"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Generate n-Grams (Terms)" to_port="document"/>
<connect from_op="Generate n-Grams (Terms)" from_port="document" to_op="Stem (WordNet)" to_port="document"/>
<connect from_op="Open WordNet Dictionary" from_port="dictionary" to_op="Stem (WordNet)" to_port="dictionary"/>
<connect from_op="Stem (WordNet)" from_port="document" to_op="Extract Sentiment (English)" to_port="document"/>
<connect from_op="Stem (WordNet)" from_port="dictionary" to_op="Extract Sentiment (English)" to_port="dictionary"/>
<connect from_op="Extract Sentiment (English)" from_port="document" to_port="document 1"/>
</process>
<connect from_op="Read Excel" from_port="output" to_op="Nominal to Text" to_port="example set input"/>
<connect from_op="Nominal to Text" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/>
<connect from_op="Process Documents from Data" from_port="example set" to_port="result 1"/>
</process>
</process>
[ /code]
