double generalCpos = paramOperator.getParameterAsDouble(JMySVMLearner.PARAMETER_L_POS); double generalCneg = paramOperator.getParameterAsDouble(JMySVMLearner.PARAMETER_L_NEG); if (paramOperator.getParameterAsBoolean(JMySVMLearner.PARAMETER_BALANCE_COST)) { generalCpos *= the_examples.count_examples() / (2.0d * (the_examples.count_examples() - the_examples.count_pos_examples())); generalCneg *= ((the_examples.count_examples()) / (2.0d * the_examples.count_pos_examples())); } for (int i = 0; i < cPos.length; i++) { cPos = generalCpos; cNeg = generalCneg;
Temperature -0.32830007919309123Outlook = sunny -0.2990901852444362Humidity -0.2759359389650189Wind = true -0.23094010767584963Outlook = rain 0.0Wind = false 0.17320508075688723Outlook = overcast 0.35248116362113585
Outlook = sunny -0.33391948463996746Humidity -0.2776748983378322Wind = true -0.25278262899833226Outlook = rain -0.12521980673998773Temperature -0.060810818269701084Wind = false 0.18958697174874925Outlook = overcast 0.5411008440732543
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.5.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.5.002" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.5.002" expanded="true" height="60" name="Retrieve Golf" width="90" x="45" y="120"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="nominal_to_numerical" compatibility="6.5.002" expanded="true" height="94" name="Nominal to Numerical" width="90" x="179" y="120"> <list key="comparison_groups"/> </operator> <operator activated="true" class="generate_weight_stratification" compatibility="6.5.002" expanded="true" height="76" name="Generate Weight (Stratification)" width="90" x="313" y="120"> <parameter key="total_weight" value="14.0"/> </operator> <operator activated="true" class="support_vector_machine" compatibility="6.5.002" expanded="true" height="112" name="SVM" width="90" x="514" y="120"/> <connect from_op="Retrieve Golf" from_port="output" to_op="Nominal to Numerical" to_port="example set input"/> <connect from_op="Nominal to Numerical" from_port="example set output" to_op="Generate Weight (Stratification)" to_port="example set input"/> <connect from_op="Generate Weight (Stratification)" from_port="example set output" to_op="SVM" to_port="training set"/> <connect from_op="SVM" from_port="weights" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="7.0.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_direct_mailing_data" compatibility="7.0.000" expanded="true" height="68" name="Generate Direct Mailing Data" width="90" x="45" y="34"> <parameter key="number_examples" value="100000"/> </operator> <operator activated="true" class="multiply" compatibility="7.0.000" expanded="true" height="124" name="Multiply" width="90" x="112" y="136"/> <operator activated="true" class="split_validation" compatibility="7.0.000" expanded="true" height="124" name="Validation" width="90" x="246" y="34"> <process expanded="true"> <operator activated="true" class="metacost" compatibility="7.0.000" expanded="true" height="82" name="MetaCost" width="90" x="45" y="34"> <parameter key="cost_matrix" value="[0.0 115.0;0.68 -115.0]"/> <process expanded="true"> <operator activated="true" class="naive_bayes" compatibility="7.0.000" expanded="true" height="82" name="Naive Bayes" width="90" x="179" y="136"/> <connect from_port="training set" to_op="Naive Bayes" to_port="training set"/> <connect from_op="Naive Bayes" from_port="model" to_port="model"/> <portSpacing port="source_training set" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> </process> </operator> <connect from_port="training" to_op="MetaCost" to_port="training set"/> <connect from_op="MetaCost" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="7.0.000" expanded="true" height="82" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_costs" compatibility="7.0.000" expanded="true" height="82" name="Performance (Cost Meta)" width="90" x="112" y="187"> <parameter key="cost_matrix" value="[0.0 115.0;0.68 -115.0]"/> <enumeration key="class_order_definition"/> </operator> <operator activated="true" class="performance_classification" compatibility="7.0.000" expanded="true" height="82" name="Performance" width="90" x="179" y="30"> <list key="class_weights"/> </operator> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance (Cost Meta)" to_port="example set"/> <connect from_op="Performance (Cost Meta)" from_port="example set" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance (Cost Meta)" from_port="performance" to_op="Performance" to_port="performance"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="create_lift_chart" compatibility="7.0.000" expanded="true" height="103" name="Create Lift Chart" width="90" x="447" y="289"> <parameter key="target_class" value="response"/> </operator> <operator activated="true" class="split_validation" compatibility="7.0.000" expanded="true" height="124" name="Validation (2)" width="90" x="246" y="187"> <process expanded="true"> <operator activated="true" class="naive_bayes" compatibility="7.0.000" expanded="true" height="82" name="Naive Bayes (2)" width="90" x="45" y="34"/> <connect from_port="training" to_op="Naive Bayes (2)" to_port="training set"/> <connect from_op="Naive Bayes (2)" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="7.0.000" expanded="true" height="82" name="Apply Model (2)" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_costs" compatibility="7.0.000" expanded="true" height="82" name="Performance (Cost Without Meta)" width="90" x="45" y="238"> <parameter key="cost_matrix" value="[0.0 115.0;0.68 -115.0]"/> <enumeration key="class_order_definition"/> </operator> <operator activated="true" class="performance_classification" compatibility="7.0.000" expanded="true" height="82" name="Performance (2)" width="90" x="179" y="30"> <list key="class_weights"/> </operator> <connect from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (Cost Without Meta)" to_port="example set"/> <connect from_op="Performance (Cost Without Meta)" from_port="example set" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Performance (Cost Without Meta)" from_port="performance" to_op="Performance (2)" to_port="performance"/> <connect from_op="Performance (2)" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="subprocess" compatibility="7.0.000" expanded="true" height="124" name="Just playing around" width="90" x="380" y="85"> <process expanded="true"> <operator activated="true" class="performance_to_data" compatibility="7.0.000" expanded="true" height="82" name="Performance to Data" width="90" x="45" y="34"/> <operator activated="true" class="performance_to_data" compatibility="7.0.000" expanded="true" height="82" name="Performance to Data (2)" width="90" x="45" y="238"/> <operator activated="true" class="extract_macro" compatibility="7.0.000" expanded="true" height="68" name="Extract Macro" width="90" x="179" y="136"> <parameter key="macro" value="CostWith"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="Value"/> <parameter key="example_index" value="1"/> <list key="additional_macros"/> </operator> <operator activated="true" class="extract_macro" compatibility="7.0.000" expanded="true" height="68" name="Extract Macro (2)" width="90" x="179" y="238"> <parameter key="macro" value="CostWithout"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="Value"/> <parameter key="example_index" value="1"/> <list key="additional_macros"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="7.0.000" expanded="true" height="68" name="Gen Data" width="90" x="313" y="289"> <list key="attribute_values"> <parameter key="CostDifference" value="parse(%{CostWith})-parse(%{CostWithout})"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="format_numbers" compatibility="7.0.000" expanded="true" height="82" name="Saving by using meta model" width="90" x="447" y="238"> <parameter key="format_type" value="currency"/> <parameter key="locale" value="English (United Kingdom)"/> <parameter key="use_grouping" value="true"/> </operator> <connect from_port="in 1" to_op="Performance to Data" to_port="performance vector"/> <connect from_port="in 2" to_op="Performance to Data (2)" to_port="performance vector"/> <connect from_op="Performance to Data" from_port="example set" to_op="Extract Macro" to_port="example set"/> <connect from_op="Performance to Data" from_port="performance vector" to_port="out 2"/> <connect from_op="Performance to Data (2)" from_port="example set" to_op="Extract Macro (2)" to_port="example set"/> <connect from_op="Performance to Data (2)" from_port="performance vector" to_port="out 3"/> <connect from_op="Gen Data" from_port="output" to_op="Saving by using meta model" to_port="example set input"/> <connect from_op="Saving by using meta model" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="source_in 3" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> <portSpacing port="sink_out 3" spacing="0"/> <portSpacing port="sink_out 4" spacing="0"/> </process> </operator> <connect from_op="Generate Direct Mailing Data" from_port="output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Validation" to_port="training"/> <connect from_op="Multiply" from_port="output 2" to_op="Validation (2)" to_port="training"/> <connect from_op="Multiply" from_port="output 3" to_op="Create Lift Chart" to_port="example set"/> <connect from_op="Validation" from_port="model" to_op="Create Lift Chart" to_port="model"/> <connect from_op="Validation" from_port="averagable 1" to_op="Just playing around" to_port="in 1"/> <connect from_op="Create Lift Chart" from_port="model" to_port="result 5"/> <connect from_op="Create Lift Chart" from_port="lift pareto chart" to_port="result 6"/> <connect from_op="Validation (2)" from_port="model" to_port="result 1"/> <connect from_op="Validation (2)" from_port="averagable 1" to_op="Just playing around" to_port="in 2"/> <connect from_op="Just playing around" from_port="out 1" to_port="result 2"/> <connect from_op="Just playing around" from_port="out 2" to_port="result 3"/> <connect from_op="Just playing around" from_port="out 3" to_port="result 4"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="84"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> <portSpacing port="sink_result 5" spacing="0"/> <portSpacing port="sink_result 6" spacing="0"/> <portSpacing port="sink_result 7" spacing="0"/> </process> </operator></process>
