<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.013"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="5.3.013" expanded="true" height="60" name="Retrieve Iris" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="optimize_selection_forward" compatibility="5.3.013" expanded="true" height="94" name="Forward Selection" width="90" x="179" y="30"> <process expanded="true"> <operator activated="true" class="x_validation" compatibility="5.3.013" expanded="true" height="112" name="Validation" width="90" x="45" y="30"> <description>A cross-validation evaluating a decision tree model.</description> <process expanded="true"> <operator activated="true" class="decision_tree" compatibility="5.3.013" expanded="true" height="76" name="Decision Tree" width="90" x="45" y="30"/> <connect from_port="training" to_op="Decision Tree" to_port="training set"/> <connect from_op="Decision Tree" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="5.3.013" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.3.013" expanded="true" height="76" name="Performance" width="90" x="179" y="30"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="log" compatibility="5.3.013" expanded="true" height="76" name="Log" width="90" x="246" y="30"> <list key="log"> <parameter key="performance" value="operator.Validation.value.performance"/> <parameter key="attributes" value="operator.Forward Selection.value.feature_names"/> </list> </operator> <connect from_port="example set" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="averagable 1" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="performance"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> </process> </operator> <connect from_op="Retrieve Iris" from_port="output" to_op="Forward Selection" to_port="example set"/> <connect from_op="Forward Selection" from_port="attribute weights" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
