<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.4.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.4.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="subprocess" compatibility="6.4.000" expanded="true" height="76" name="DemoData" width="90" x="45" y="30"> <process expanded="true"> <operator activated="true" class="text:create_document" compatibility="6.4.001" expanded="true" height="60" name="Create Document" width="90" x="45" y="30"> <parameter key="text" value="我是Class1。"/> </operator> <operator activated="true" class="text:create_document" compatibility="6.4.001" expanded="true" height="60" name="Create Document (2)" width="90" x="45" y="120"> <parameter key="text" value="我是Class2。"/> </operator> <operator activated="true" class="collect" compatibility="6.4.000" expanded="true" height="94" name="Collect" width="90" x="246" y="75"/> <connect from_op="Create Document" from_port="output" to_op="Collect" to_port="input 1"/> <connect from_op="Create Document (2)" from_port="output" to_op="Collect" to_port="input 2"/> <connect from_op="Collect" from_port="collection" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="multiply" compatibility="6.4.000" expanded="true" height="94" name="Multiply" width="90" x="112" y="120"/> <operator activated="true" class="text:filter_documents_by_content" compatibility="6.4.001" expanded="true" height="76" name="Filter Class1" width="90" x="246" y="30"> <parameter key="string" value="Class1"/> <description align="center" color="transparent" colored="false" width="126">&#35831;&#36755;&#20837;&#24744;&#30340;&#25991;&#26412;&#23383;&#31526;&#20018;&#22312;&#36825;&#37324;&#12290;</description> </operator> <operator activated="true" class="text:filter_documents_by_content" compatibility="6.4.001" expanded="true" height="76" name="Filter Class2" width="90" x="246" y="165"> <parameter key="string" value="Class2"/> <description align="center" color="transparent" colored="false" width="126">&#35831;&#36755;&#20837;&#24744;&#30340;&#25991;&#26412;&#23383;&#31526;&#20018;&#22312;&#36825;&#37324;&#12290;</description> </operator> <operator activated="true" class="text:documents_to_data" compatibility="6.4.001" expanded="true" height="76" name="Documents to Data" width="90" x="380" y="30"> <parameter key="text_attribute" value="ForumPost"/> </operator> <operator activated="true" class="generate_attributes" compatibility="6.4.000" expanded="true" height="76" name="Generate Attributes" width="90" x="514" y="30"> <list key="function_descriptions"> <parameter key="Label" value=""Class1""/> </list> </operator> <operator activated="true" class="text:documents_to_data" compatibility="6.4.001" expanded="true" height="76" name="Documents to Data (2)" width="90" x="390" y="165"> <parameter key="text_attribute" value="ForumPost"/> </operator> <operator activated="true" class="generate_attributes" compatibility="6.4.000" expanded="true" height="76" name="Generate Attributes (2)" width="90" x="514" y="165"> <list key="function_descriptions"> <parameter key="Label" value=""Class2""/> </list> </operator> <operator activated="true" class="append" compatibility="6.4.000" expanded="true" height="94" name="Append" width="90" x="648" y="120"/> <connect from_op="DemoData" from_port="out 1" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Filter Class1" to_port="documents 1"/> <connect from_op="Multiply" from_port="output 2" to_op="Filter Class2" to_port="documents 1"/> <connect from_op="Filter Class1" from_port="documents" to_op="Documents to Data" to_port="documents 1"/> <connect from_op="Filter Class2" from_port="documents" to_op="Documents to Data (2)" to_port="documents 1"/> <connect from_op="Documents to Data" from_port="example set" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Append" to_port="example set 1"/> <connect from_op="Documents to Data (2)" from_port="example set" to_op="Generate Attributes (2)" to_port="example set input"/> <connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Append" to_port="example set 2"/> <connect from_op="Append" from_port="merged set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <description align="center" color="red" colored="true" height="66" resized="true" width="233" x="10" y="241"><br/>http://www.rapidminerchina.com</description> </process> </operator></process>
