Hi Team,
I am just starting on rapid miner and i wanted to understand how a Rapid Miner process can be run from the command line.
I have searched this forum for possible resolutions to my problem but i unfortunately couldn't find an answer.
Here is what i am doing:
Step1: I have created a very basic process (correlation analysis) in the rapid miner 5.3.013 edition. This output of the process is an "xls" file generated from the "write excel" operator. I am saving this file as "Test.xls" on a path in my local desktop - "C:\Test RM"
Step 2: Open the Command Prompt and move to the directory where rapidminer.bat is located.
cd C:\Program Files\Rapid-I\RapidMiner5\scripts
Step 3: Run the batch process from the current location (scripts)
rapidminer.bat -f C:\Users\kunal.krishnan\.RapidMiner5\repositories\Local Repository\processes\Pumps - Logisitic Regression\Process 1 - Correlation Analysis - 09052013.rmp
I have also tried ".xml" as an extension.
Result: If i run the process directly from Rapid Miner, i can see the file being generated in the local folder, but if i run this from the command prompt using the above process, it looks like the Rapid Miner process doesn't run.
Error:
RAPIDMINER_HOME is not set. Trying the directory 'C:\Program Files\Rapid-I\RapidMiner5\scripts\..'...
Using local jre: C:\Program Files\Rapid-I\RapidMiner5\scripts\..\jre\bin\java.exe..
Starting RapidMiner from 'C:\Program Files\Rapid-I\RapidMiner5\scripts\..' using
classes from 'C:\Program Files\Rapid-I\RapidMiner5\scripts\..\lib\rapidminer.jar'...
Creating file "C:\Users\kunal.krishnan\AppData\Roaming\check_rm_java_version"
Java Version: 1.7.0_11
Removing file "C:\Users\kunal.krishnan\AppData\Roaming\check_rm_java_version"
Starting in multicore mode with G1 garbage collector...
RapidMiner version 5.3.013, Copyright (C) 2001-2012
RapidMiner comes with ABSOLUTELY NO WARRANTY; This is free software,
and you are welcome to redistribute it under certain conditions;
see license information in the file named LICENSE.
Sep 09, 2013 5:51:31 PM com.rapid_i.Launcher ensureRapidMinerHomeSet
INFO: rapidminer.home is 'C:\Program Files\Rapid-I\RapidMiner5\scripts\..'.
Sep 09, 2013 5:51:31 PM com.rapidminer.tools.ParameterService init
INFO: Reading configuration resource com/rapidminer/resources/rapidminerrc.
Sep 09, 2013 5:51:31 PM com.rapidminer.tools.I18N <clinit>
INFO: Set locale to en.
Sep 09, 2013 5:51:33 PM com.rapidminer.tools.expression.parser.ExpressionParserF
actory <clinit>
INFO: Default version of expression parser registered successfully
Sep 09, 2013 5:51:34 PM com.rapidminer.parameter.ParameterTypePassword decryptPa
ssword
WARNING: Password in XML file looks like unencrypted plain text.
Sep 09, 2013 5:51:35 PM com.rapidminer.tools.OperatorService init
INFO: Number of registered operator classes: 443; number of registered operator
descriptions: 444; number of replacements: 403
Sep 09, 2013 5:51:35 PM com.rapidminer.tools.jdbc.JDBCProperties <init>
WARNING: Missing database driver class name for ODBC Bridge (e.g. Access)
Sep 09, 2013 5:51:35 PM com.rapidminer.tools.jdbc.JDBCProperties registerDrivers
INFO: JDBC driver ca.ingres.jdbc.IngresDriver not found. Probably the driver is
not installed.
[Fatal Error] :1:1: Premature end of file.
Sep 09, 2013 5:51:36 PM com.rapidminer.RapidMiner readProcessFile
SEVERE: Cannot read process definition file C:\Users\kunal.krishnan\.RapidMiner5
\repositories\Local!
Sep 09, 2013 5:51:36 PM com.rapidminer.RapidMinerCommandLine run
WARNING: Cannot read process setup C:\Users\kunal.krishnan\.RapidMiner5\reposito
ries//Local: C:\Users\kunal.krishnan\.RapidMiner5\repositories\Local (The system
cannot find the file specified)
java.io.FileNotFoundException: C:\Users\kunal.krishnan\.RapidMiner5\repositories
\Local (The system cannot find the file specified)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(Unknown Source)
at com.rapidminer.Process.<init>(Process.java:236)
at com.rapidminer.RapidMiner.readProcessFile(RapidMiner.java:504)
at com.rapidminer.RapidMiner.readProcessFile(RapidMiner.java:493)
at com.rapidminer.RapidMinerCommandLine.run(RapidMinerCommandLine.java:1
38)
at com.rapidminer.RapidMinerCommandLine.main(RapidMinerCommandLine.java:
196)
Usage: java [-options] class [args...]
(to execute a class)
or java [-options] -jar jarfile [args...]
(to execute a jar file)
where options include:
-d32 use a 32-bit data model if available
-d64 use a 64-bit data model if available
-server to select the "server" VM
-hotspot is a synonym for the "server" VM [deprecated]
The default VM is server.
-cp <class search path of directories and zip/jar files>
-classpath <class search path of directories and zip/jar files>
A ; separated list of directories, JAR archives,
and ZIP archives to search for class files.
-D<name>=<value>
set a system property
-verbose:[class|gc|jni]
enable verbose output
-version print product version and exit
-version:<value>
require the specified version to run
-showversion print product version and continue
-jre-restrict-search | -no-jre-restrict-search
include/exclude user private JREs in the version search
-? -help print this help message
-X print help on non-standard options
-ea[:<packagename>...|:<classname>]
-enableassertions[:<packagename>...|:<classname>]
enable assertions with specified granularity
-da[:<packagename>...|:<classname>]
-disableassertions[:<packagename>...|:<classname>]
disable assertions with specified granularity
-esa | -enablesystemassertions
enable system assertions
-dsa | -disablesystemassertions
disable system assertions
-agentlib:<libname>[=<options>]
load native agent library <libname>, e.g. -agentlib:hprof
see also, -agentlib:jdwp=help and -agentlib:hprof=help
-agentpath:<pathname>[=<options>]
load native agent library by full pathname
-javaagent:<jarpath>[=<options>]
load Java programming language agent, see java.lang.instrument
-splash:<imagepath>
show splash screen with specified image
See
http://www.oracle.com/technetwork/java/javase/documentation/index.html for more details.
Request your kind help in resolving the process.
Thanks a lot.
Kunal
