<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.6.000-SNAPSHOT"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.6.000-SNAPSHOT" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.6.000-SNAPSHOT" expanded="true" height="60" name="Retrieve Deals" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Deals"/> </operator> <operator activated="true" class="parallel_decision_tree" compatibility="6.6.000-SNAPSHOT" expanded="true" height="76" name="Decision Tree" width="90" x="246" y="30"/> <operator activated="true" class="write_model" compatibility="6.6.000-SNAPSHOT" expanded="true" height="60" name="Write Model" width="90" x="447" y="30"> <parameter key="model_file" value="C:\Users\XYZ\Desktop\1.mod"/> <parameter key="output_type" value="XML"/> </operator> <connect from_op="Retrieve Deals" from_port="output" to_op="Decision Tree" to_port="training set"/> <connect from_op="Decision Tree" from_port="model" to_op="Write Model" to_port="input"/> <connect from_op="Write Model" from_port="through" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
