Altair RISE
Nominate Yourself Now!
"Loop SubSet (Brute Force) for SVM models"
User: "ltor"
New Altair Community Member
Updated by Jocelyn
First, I am a newbie in machine learning and RapidMiner is fantastic to quickly learn the methods without code learning !
I try scikit and R but I prefer Rapidminer to get more time for real work...
In my case, I got a good model (SVM, RBF) for a set of 26 samples (13 in each class, 2 classes)  with 15 features by choosing only two features...how I choose the two good ones ? by making a naive bayes classification and looking at their probabilty curves and keep only those with the most separated ones.
To be more academic, I wanted to try brute force and log some values of the svm models like precision, accuracy, recall, class precision but the only I can get is three values performance1, performance2 and variance from this workflow :
<process version="6.5.002">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process">
    <parameter key="parallelize_main_process" value="true"/>
    <process expanded="true">
      <operator activated="true" class="read_excel" compatibility="6.5.002" expanded="true" height="60" name="Read Excel" width="90" x="45" y="30">
        <parameter key="excel_file" value="/home/toto/Bureau/Modelisation/Travail/BETA-IL.xls"/>
        <parameter key="sheet_number" value="2"/>
        <parameter key="imported_cell_range" value="A1:IV27"/>
        <parameter key="first_row_as_names" value="false"/>
        <list key="annotations">
          <parameter key="0" value="Name"/>
        </list>
        <parameter key="date_format" value=""/>
        <parameter key="time_zone" value="SYSTEM"/>
        <parameter key="locale" value="French"/>
          <parameter key="0" value="ID.false.integer.attribute"/>
          <parameter key="1" value="NOM.false.polynominal.attribute"/>
          <parameter key="2" value="Malade.true.polynominal.attribute"/>
          <parameter key="3" value="Age.false.integer.attribute"/>
          <parameter key="4" value="LM-HDMB.false.polynominal.attribute"/>
          <parameter key="5" value="LM.true.polynominal.attribute"/>
          <parameter key="6" value="sexe.false.polynominal.attribute"/>
          <parameter key="7" value="Statut.false.polynominal.attribute"/>
          <parameter key="8" value="D-PHON-LH-22.true.real.attribute"/>
          <parameter key="9" value="D-PHON-RH-22.true.real.attribute"/>
          <parameter key="10" value="D-PHON-LH-44.true.real.attribute"/>
          <parameter key="11" value="D-PHON-RH-44.true.numeric.attribute"/>
          <parameter key="12" value="D-PHON-LH-45.true.real.attribute"/>
          <parameter key="13" value="D-PHON-RH-45.true.real.attribute"/>
          <parameter key="14" value="D-SEM-LH-21.true.real.attribute"/>
          <parameter key="15" value="D-SEM-RH-21.true.real.attribute"/>
          <parameter key="16" value="D-SEM-LH-47.true.real.attribute"/>
          <parameter key="17" value="D-SEM-RH-47.true.real.attribute"/>
          <parameter key="18" value="IL025-44.true.real.attribute"/>
          <parameter key="19" value="IL025-45.true.real.attribute"/>
          <parameter key="20" value="IL025-47.true.real.attribute"/>
          <parameter key="21" value="IL025-22.true.real.attribute"/>
          <parameter key="22" value="IL025-21.true.real.attribute"/>
        </list>
        <parameter key="read_not_matching_values_as_missings" value="true"/>
        <parameter key="datamanagement" value="double_array"/>
      <operator activated="true" class="select_attributes" compatibility="6.5.002" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="30">
        <parameter key="attribute" value=""/>
        <parameter key="attributes" value="Malade|IL025-47|IL025-45|IL025-44|IL025-22|IL025-21|D-SEM-RH-47|D-SEM-RH-21|D-SEM-LH-47|D-SEM-LH-21|D-PHON-RH-45|D-PHON-RH-44|D-PHON-RH-22|D-PHON-LH-45|D-PHON-LH-44|D-PHON-LH-22"/>
      <operator activated="true" class="set_role" compatibility="6.5.002" expanded="true" height="76" name="Set Role (3)" width="90" x="313" y="30">
        <parameter key="attribute_name" value="Malade"/>
      <operator activated="true" class="normalize" compatibility="6.5.002" expanded="true" height="94" name="Normalize" width="90" x="447" y="30">
        <parameter key="return_preprocessing_model" value="false"/>
        <parameter key="create_view" value="false"/>
        <parameter key="attribute_filter_type" value="all"/>
        <parameter key="attributes" value="|IL025-45|IL025-44"/>
        <parameter key="value_type" value="numeric"/>
        <parameter key="except_value_type" value="real"/>
        <parameter key="block_type" value="value_series"/>
        <parameter key="except_block_type" value="value_series_end"/>
        <parameter key="method" value="range transformation"/>
        <parameter key="min" value="-1.0"/>
        <parameter key="max" value="1.0"/>
      <operator activated="true" class="loop_attribute_subsets" compatibility="6.5.002" expanded="true" height="60" name="Loop Subsets" width="90" x="581" y="30">
        <parameter key="use_exact_number" value="false"/>
        <parameter key="exact_number_of_attributes" value="-1"/>
        <parameter key="min_number_of_attributes" value="2"/>
        <parameter key="limit_max_number" value="false"/>
        <parameter key="max_number_of_attributes" value="-1"/>
        <parameter key="parallelize_subprocess" value="true"/>
          <operator activated="true" class="x_validation" compatibility="6.5.002" expanded="true" height="112" name="Validation (2)" width="90" x="313" y="30">
            <parameter key="create_complete_model" value="false"/>
            <parameter key="average_performances_only" value="true"/>
            <parameter key="leave_one_out" value="true"/>
            <parameter key="number_of_validations" value="3"/>
            <parameter key="sampling_type" value="stratified sampling"/>
            <parameter key="use_local_random_seed" value="false"/>
            <parameter key="local_random_seed" value="1992"/>
            <parameter key="parallelize_training" value="true"/>
            <parameter key="parallelize_testing" value="true"/>
              <operator activated="true" class="polynomial_by_binomial_classification" compatibility="6.5.002" expanded="true" height="76" name="Polynominal by Binominal Classification (2)" width="90" x="184" y="30">
                <parameter key="classification_strategies" value="1 against all"/>
                <parameter key="random_code_multiplicator" value="2.0"/>
                <parameter key="parallelize_learning_process" value="true"/>
                  <operator activated="true" class="support_vector_machine_libsvm" compatibility="6.5.002" expanded="true" height="76" name="SVM" width="90" x="447" y="30">
                    <parameter key="svm_type" value="C-SVC"/>
                    <parameter key="kernel_type" value="rbf"/>
                    <parameter key="degree" value="3"/>
                    <parameter key="gamma" value="0.5"/>
                    <parameter key="coef0" value="0.0"/>
                    <parameter key="C" value="1000.0"/>
                    <parameter key="nu" value="0.5"/>
                    <parameter key="cache_size" value="80"/>
                    <parameter key="epsilon" value="0.001"/>
                    <parameter key="p" value="0.1"/>
                    <list key="class_weights"/>
                    <parameter key="shrinking" value="true"/>
                    <parameter key="calculate_confidences" value="false"/>
                    <parameter key="confidence_for_multiclass" value="true"/>
                  <connect from_port="training set" to_op="SVM" to_port="training set"/>
                  <connect from_op="SVM" from_port="model" to_port="model"/>
                  <portSpacing port="source_training set" spacing="0"/>
                </process>
              <connect from_port="training" to_op="Polynominal by Binominal Classification (2)" to_port="training set"/>
              <connect from_op="Polynominal by Binominal Classification (2)" from_port="model" to_port="model"/>
              <portSpacing port="source_training" spacing="0"/>
            </process>
              <operator activated="true" class="apply_model" compatibility="6.5.002" expanded="true" height="76" name="Apply Model (2)" width="90" x="45" y="30">
              <operator activated="true" class="performance" compatibility="6.5.002" expanded="true" height="76" name="Performance (2)" width="90" x="246" y="30">
                <parameter key="use_example_weights" value="true"/>
              <connect from_port="model" to_op="Apply Model (2)" to_port="model"/>
              <connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/>
              <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/>
              <connect from_op="Performance (2)" from_port="performance" to_port="averagable 1"/>
              <portSpacing port="sink_averagable 1" spacing="0"/>
              <portSpacing port="sink_averagable 2" spacing="0"/>
            </process>
          <operator activated="true" class="log" compatibility="6.5.002" expanded="true" height="112" name="Log" width="90" x="715" y="30">
            <parameter key="filename" value="/home/toto/Bureau/Modelisation/Travail/subset.log"/>
            <list key="log">
              <parameter key="Iteration" value="operator.Loop Subsets.value.iteration"/>
              <parameter key="Attributes" value="operator.Loop Subsets.value.feature_names"/>
              <parameter key="Performance" value="operator.Performance (2).value.performance"/>
              <parameter key="Performance1" value="operator.Validation (2).value.performance1"/>
              <parameter key="Performance2" value="operator.Validation (2).value.performance2"/>
              <parameter key="Variance" value="operator.Validation (2).value.variance"/>
            </list>
            <parameter key="sorting_type" value="none"/>
            <parameter key="sorting_k" value="100"/>
            <parameter key="persistent" value="false"/>
          <connect from_port="example set" to_op="Validation (2)" to_port="training"/>
          <connect from_op="Validation (2)" from_port="model" to_op="Log" to_port="through 1"/>
          <connect from_op="Validation (2)" from_port="training" to_op="Log" to_port="through 3"/>
          <connect from_op="Validation (2)" from_port="averagable 1" to_op="Log" to_port="through 2"/>
        </process>
      <connect from_op="Read Excel" from_port="output" to_op="Select Attributes" to_port="example set input"/>
      <connect from_op="Select Attributes" from_port="example set output" to_op="Set Role (3)" to_port="example set input"/>
      <connect from_op="Set Role (3)" from_port="example set output" to_op="Normalize" to_port="example set input"/>
      <connect from_op="Normalize" from_port="example set output" to_op="Loop Subsets" to_port="example set"/>
      <connect from_op="Loop Subsets" from_port="example set" to_port="result 1"/>
    </process>
</process>
Any idea, first to get what I wanted and then about what are performance1,performance2 and variance ont the output of  validation process?
Thanks in advance,
L.T
1 - 4 of 41
    maybe this can help you. It is a bit more fexible than the logging.
    Be careful with the parallelization. The remember recall works like a goto.
    Martin
    <process version="6.5.001">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
          <operator activated="true" class="retrieve" compatibility="6.5.001" expanded="true" height="60" name="Retrieve Golf" width="90" x="45" y="30">
            <parameter key="repository_entry" value="//Samples/data/Golf"/>
          <operator activated="true" class="loop_attribute_subsets" compatibility="6.5.001" expanded="true" height="60" name="Loop Subsets" width="90" x="179" y="30">
              <operator activated="true" class="x_validation" compatibility="6.5.001" expanded="true" height="112" name="Validation (2)" width="90" x="112" y="30">
                  <operator activated="true" class="naive_bayes" compatibility="6.5.001" expanded="true" height="76" name="Naive Bayes" width="90" x="179" y="30"/>
                  <connect from_port="training" to_op="Naive Bayes" to_port="training set"/>
                  <connect from_op="Naive Bayes" from_port="model" to_port="model"/>
                </process>
                  <operator activated="true" class="apply_model" compatibility="6.5.001" expanded="true" height="76" name="Apply Model (2)" width="90" x="45" y="30">
                  <operator activated="true" class="performance_binominal_classification" compatibility="6.5.001" expanded="true" height="76" name="Performance (4)" width="90" x="380" y="30">
                    <parameter key="precision" value="true"/>
                    <parameter key="recall" value="true"/>
                  <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (4)" to_port="labelled data"/>
                  <connect from_op="Performance (4)" from_port="performance" to_port="averagable 1"/>
                </process>
              <operator activated="true" class="performance_to_data" compatibility="6.5.001" expanded="true" height="76" name="Performance to Data" width="90" x="313" y="120"/>
              <operator activated="true" class="handle_exception" compatibility="6.5.001" expanded="true" height="76" name="Handle Exception" width="90" x="581" y="120">
                  <operator activated="true" class="recall" compatibility="6.5.001" expanded="true" height="60" name="Recall" width="90" x="45" y="75">
                    <parameter key="name" value="performance"/>
                    <parameter key="remove_from_store" value="false"/>
                  <operator activated="true" class="append" compatibility="6.5.001" expanded="true" height="94" name="Append" width="90" x="179" y="30"/>
                  <operator activated="true" class="remember" compatibility="6.5.001" expanded="true" height="60" name="Remember" width="90" x="313" y="30">
                  <connect from_port="in 1" to_op="Append" to_port="example set 1"/>
                  <connect from_op="Recall" from_port="result" to_op="Append" to_port="example set 2"/>
                  <connect from_op="Append" from_port="merged set" to_op="Remember" to_port="store"/>
                  <portSpacing port="source_in 2" spacing="0"/>
                </process>
                  <operator activated="true" class="remember" compatibility="6.5.001" expanded="true" height="60" name="Remember (2)" width="90" x="45" y="30">
                  <connect from_port="in 1" to_op="Remember (2)" to_port="store"/>
                </process>
              <connect from_op="Validation (2)" from_port="averagable 1" to_op="Performance to Data" to_port="performance vector"/>
              <connect from_op="Performance to Data" from_port="example set" to_op="Handle Exception" to_port="in 1"/>
            </process>
          <operator activated="true" class="recall" compatibility="6.5.001" expanded="true" height="60" name="Recall (2)" width="90" x="380" y="30">
          <connect from_op="Retrieve Golf" from_port="output" to_op="Loop Subsets" to_port="example set"/>
          <connect from_op="Recall (2)" from_port="result" to_port="result 1"/>
        </process>
    </process>
    User: "ltor"
    OP
    Thanks a lot for your answer !
    I tried this workflow and tried to solve an issue when I executed it but without success...I do not really well undestrand the recall/append structure  ???
    The issue is a message from Recall(2) : No object name Performance was found during retrieval from obejct store.
    I have read in an other post, this could be a default in the order of the tasks, but Recall(2) is the first in the Tree View of the workflow...any idea ?
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
        <parameter key="parallelize_main_process" value="false"/>
          <operator activated="true" class="recall" compatibility="6.5.002" expanded="true" height="60" name="Recall (2)" width="90" x="715" y="30">
            <parameter key="name" value="Performance"/>
            <parameter key="io_object" value="ExampleSet"/>
          <operator activated="true" class="read_excel" compatibility="6.5.002" expanded="true" height="60" name="Read Excel" width="90" x="45" y="255">
            </list>
              <parameter key="2" value="Malade.true.binominal.attribute"/>
            </list>
          <operator activated="true" class="select_attributes" compatibility="6.5.002" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="255">
            <parameter key="attributes" value="D-PHON-LH-22|D-PHON-LH-44|D-PHON-LH-45|D-PHON-RH-22|D-PHON-RH-44|D-PHON-RH-45|D-SEM-LH-21|D-SEM-LH-47|D-SEM-RH-21|D-SEM-RH-47|IL025-21|IL025-22|IL025-44|IL025-45|IL025-47|Malade"/>
          <operator activated="true" class="set_role" compatibility="6.5.002" expanded="true" height="76" name="Set Role (3)" width="90" x="313" y="255">
          <operator activated="true" class="normalize" compatibility="6.5.002" expanded="true" height="94" name="Normalize" width="90" x="447" y="255">
            <parameter key="attributes" value="|IL025-47|IL025-45|IL025-44|IL025-22|IL025-21|D-SEM-RH-47|D-SEM-RH-21|D-SEM-LH-47|D-SEM-LH-21|D-PHON-RH-45|D-PHON-RH-44|D-PHON-RH-22|D-PHON-LH-45|D-PHON-LH-44|D-PHON-LH-22"/>
          <operator activated="true" class="loop_attribute_subsets" compatibility="6.5.002" expanded="true" height="60" name="Loop Subsets" width="90" x="514" y="30">
            <parameter key="parallelize_subprocess" value="false"/>
              <operator activated="true" class="x_validation" compatibility="6.5.002" expanded="true" height="112" name="Validation (2)" width="90" x="112" y="30">
                <parameter key="parallelize_training" value="false"/>
                <parameter key="parallelize_testing" value="false"/>
                  <operator activated="true" class="support_vector_machine_libsvm" compatibility="6.5.002" expanded="true" height="76" name="SVM" width="90" x="179" y="30">
                  <connect from_port="training" to_op="SVM" to_port="training set"/>
                </process>
                  <operator activated="true" class="performance_binominal_classification" compatibility="6.5.002" expanded="true" height="76" name="Performance" width="90" x="246" y="30">
                    <parameter key="main_criterion" value="first"/>
                    <parameter key="accuracy" value="true"/>
                    <parameter key="classification_error" value="false"/>
                    <parameter key="kappa" value="false"/>
                    <parameter key="AUC (optimistic)" value="false"/>
                    <parameter key="AUC" value="false"/>
                    <parameter key="AUC (pessimistic)" value="false"/>
                    <parameter key="precision" value="false"/>
                    <parameter key="recall" value="false"/>
                    <parameter key="lift" value="false"/>
                    <parameter key="fallout" value="false"/>
                    <parameter key="f_measure" value="false"/>
                    <parameter key="false_positive" value="true"/>
                    <parameter key="false_negative" value="true"/>
                    <parameter key="true_positive" value="false"/>
                    <parameter key="true_negative" value="false"/>
                    <parameter key="sensitivity" value="false"/>
                    <parameter key="specificity" value="false"/>
                    <parameter key="youden" value="false"/>
                    <parameter key="positive_predictive_value" value="false"/>
                    <parameter key="negative_predictive_value" value="false"/>
                    <parameter key="psep" value="false"/>
                    <parameter key="skip_undefined_labels" value="true"/>
                  <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance" to_port="labelled data"/>
                  <connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
                </process>
              <operator activated="true" class="performance_to_data" compatibility="6.5.002" expanded="true" height="76" name="Performance to Data" width="90" x="380" y="75"/>
              <operator activated="true" class="handle_exception" compatibility="6.5.002" expanded="true" height="76" name="Handle Exception" width="90" x="648" y="75">
                <parameter key="parallelize_try" value="false"/>
                <parameter key="parallelize_catch" value="false"/>
                  <operator activated="true" class="recall" compatibility="6.5.002" expanded="true" height="60" name="Recall" width="90" x="45" y="75">
                  <operator activated="true" class="append" compatibility="6.5.002" expanded="true" height="94" name="Append" width="90" x="179" y="30">
                    <parameter key="merge_type" value="all"/>
                  <operator activated="true" class="remember" compatibility="6.5.002" expanded="true" height="60" name="Remember" width="90" x="313" y="30">
                    <parameter key="store_which" value="1"/>
                    <parameter key="remove_from_process" value="true"/>
                  <connect from_port="in 1" to_op="Append" to_port="example set 2"/>
                  <connect from_port="in 2" to_port="out 1"/>
                  <connect from_op="Recall" from_port="result" to_op="Append" to_port="example set 1"/>
                  <portSpacing port="source_in 3" spacing="0"/>
                </process>
                  <operator activated="true" class="remember" compatibility="6.5.002" expanded="true" height="60" name="Remember (2)" width="90" x="45" y="30">
                </process>
              <connect from_op="Performance to Data" from_port="performance vector" to_op="Handle Exception" to_port="in 2"/>
            </process>
        </process>
    </process>
    User: "JEdward"
    Yes, it's simply that you need to change the order of the process so the Recall happens last.
    3 options:
    1. You can drag the Recall operator in the tree view you show here to the end of your process.
    2. If you go to the menu bar Process -> Operator Execution Order -> Order Execution you can right click and change the order the process is executed.
    3. You can add a subprocess with the recall inside and force the order to occur as part of the process chain.  (See below example as this is the method I favour).
    <process version="6.4.000">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
          <operator activated="true" class="read_excel" compatibility="6.4.000" expanded="true" height="60" name="Read Excel" width="90" x="45" y="255">
            </list>
            </list>
          <operator activated="true" class="select_attributes" compatibility="6.4.000" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="255">
          <operator activated="true" class="set_role" compatibility="6.4.000" expanded="true" height="76" name="Set Role (3)" width="90" x="313" y="255">
          <operator activated="true" class="normalize" compatibility="6.4.000" expanded="true" height="94" name="Normalize" width="90" x="447" y="255">
          <operator activated="true" class="loop_attribute_subsets" compatibility="6.4.000" expanded="true" height="60" name="Loop Subsets" width="90" x="514" y="30">
              <operator activated="true" class="x_validation" compatibility="6.4.000" expanded="true" height="112" name="Validation (2)" width="90" x="112" y="30">
                  <operator activated="true" class="support_vector_machine_libsvm" compatibility="6.4.000" expanded="true" height="76" name="SVM" width="90" x="179" y="30">
                </process>
                  <operator activated="true" class="apply_model" compatibility="6.4.000" expanded="true" height="76" name="Apply Model (2)" width="90" x="45" y="30">
                  <operator activated="true" class="performance_binominal_classification" compatibility="6.4.000" expanded="true" height="76" name="Performance" width="90" x="246" y="30">
                </process>
              <operator activated="true" class="performance_to_data" compatibility="6.4.000" expanded="true" height="76" name="Performance to Data" width="90" x="380" y="75"/>
              <operator activated="true" class="handle_exception" compatibility="6.4.000" expanded="true" height="76" name="Handle Exception" width="90" x="648" y="75">
                  <operator activated="true" class="recall" compatibility="6.4.000" expanded="true" height="60" name="Recall" width="90" x="45" y="75">
                  <operator activated="true" class="append" compatibility="6.4.000" expanded="true" height="94" name="Append" width="90" x="179" y="30"/>
                  <operator activated="true" class="remember" compatibility="6.4.000" expanded="true" height="60" name="Remember" width="90" x="313" y="30">
                </process>
                  <operator activated="true" class="remember" compatibility="6.4.000" expanded="true" height="60" name="Remember (2)" width="90" x="45" y="30">
                </process>
            </process>
          <operator activated="true" class="subprocess" compatibility="6.4.000" expanded="true" height="76" name="Last Recall is in here" width="90" x="648" y="75">
              <operator activated="true" class="recall" compatibility="6.4.000" expanded="true" height="60" name="Recall (2)" width="90" x="313" y="120">
              <connect from_op="Recall (2)" from_port="result" to_port="out 1"/>
            </process>
          <connect from_op="Loop Subsets" from_port="example set" to_op="Last Recall is in here" to_port="in 1"/>
          <connect from_op="Last Recall is in here" from_port="out 1" to_port="result 1"/>
        </process>
    </process>
    User: "ltor"
    OP
    Hi, Thanks a lot !
    Unfortunately, I tried and I got the same error...I will try to understand the recall process later I think  :-\
    In the same time, I have found the trouble in my first workflow without recall process, it was the wrong "Performance" process, I use now the "Performance (Binomial Classification)" and I have access to recall, precision and accuracy parameters for logging.
    But  ;) I have a new problem, the great majority of the attributes combinations logged are perfect in terms of performance whereas it is not the case if you evaluate them individually !
    Anyone see my beginner's mystake ?
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="">
          <operator activated="true" class="read_excel" compatibility="6.5.002" expanded="true" height="60" name="Read Excel" width="90" x="45" y="75">
            </list>
            </list>
          <operator activated="true" class="select_attributes" compatibility="6.5.002" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="75">
          <operator activated="true" class="set_role" compatibility="6.5.002" expanded="true" height="76" name="Set Role (3)" width="90" x="313" y="75">
          <operator activated="true" class="normalize" compatibility="6.5.002" expanded="true" height="94" name="Normalize" width="90" x="447" y="75">
          <operator activated="true" class="loop_attribute_subsets" compatibility="6.5.002" expanded="true" height="60" name="Loop Subsets" width="90" x="648" y="75">
            <parameter key="exact_number_of_attributes" value="2"/>
                </process>
                </process>
              <operator activated="true" class="apply_model" compatibility="6.5.002" expanded="true" height="76" name="Apply Model" width="90" x="313" y="30">
              <operator activated="true" class="performance_binominal_classification" compatibility="6.5.002" expanded="true" height="76" name="Performance (3)" width="90" x="447" y="30">
                <parameter key="classification_error" value="true"/>
                <parameter key="false_positive" value="false"/>
                <parameter key="false_negative" value="false"/>
              <operator activated="true" class="log" compatibility="6.5.002" expanded="true" height="94" name="Log" width="90" x="581" y="30">
                <parameter key="filename" value="/home/toto/Bureau/Modelisation/Travail/subset-v3.log"/>
                <list key="log">
                  <parameter key="Accuracy" value="operator.Performance (3).value.accuracy"/>
                  <parameter key="Precision" value="operator.Performance (3).value.precision"/>
                  <parameter key="Recall" value="operator.Performance (3).value.recall"/>
                  <parameter key="Classification_error" value="operator.Performance (3).value.classification_error"/>
                </list>
              <connect from_op="Validation (2)" from_port="model" to_op="Apply Model" to_port="model"/>
              <connect from_op="Validation (2)" from_port="training" to_op="Apply Model" to_port="unlabelled data"/>
              <connect from_op="Apply Model" from_port="labelled data" to_op="Performance (3)" to_port="labelled data"/>
              <connect from_op="Performance (3)" from_port="performance" to_op="Log" to_port="through 1"/>
              <connect from_op="Performance (3)" from_port="example set" to_op="Log" to_port="through 2"/>
            </process>
        </process>
    </process>
