"Join two tables using several attributes as key attributes"
bzavala
Hi! I need to join two tables using several attributes as key attributes. What I was doing was concatenate all these attributes and then using the new attribute as a key, but I want to know if there is any better solution than that. In addition, generate concatenation operator only allows to concatenate two attributes at time, so I need to use a lot of boxes to generate my key attribute. So, is there any way to concatenate several attributes at the time? And is there any other way to join tables using several attributes? My solution works OK but my entire process looks huge while is very simple.
Thanks in advance.
Join
MartinLiebig
if you uncheck the "use id as key" option you can have a option to use several keys to match for joining.
~Martin
bzavala
I havent realized that I was able to add entrys to add more key attributes. Sorry for such stupid question. Thanks you!
bzavala
And what about concatenating several attributes in only one step? s there a way to do that?
MartinLiebig
puh, since generate aggragation has no concat, i do not know a single operator solution for this
JEdward
The Generate Attributes operator has concat(), that might help.
MartinLiebig
yep, but to that for several attributes you need to add a loop attributes or so around :-)
So at least 2 operators.
