<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.013"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="5.3.013" expanded="true" height="60" name="Retrieve Sonar" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Sonar"/> </operator> <operator activated="true" class="optimize_selection_forward" compatibility="5.3.013" expanded="true" height="94" name="Forward Selection" width="90" x="179" y="30"> <parameter key="speculative_rounds" value="1"/> <process expanded="true"> <operator activated="true" class="x_validation" compatibility="5.3.013" expanded="true" height="112" name="Validation" width="90" x="45" y="75"> <description>A cross-validation evaluating a decision tree model.</description> <parameter key="use_local_random_seed" value="true"/> <process expanded="true"> <operator activated="true" class="naive_bayes" compatibility="5.3.013" expanded="true" height="76" name="Naive Bayes" width="90" x="45" y="30"/> <connect from_port="training" to_op="Naive Bayes" to_port="training set"/> <connect from_op="Naive Bayes" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="5.3.013" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.3.013" expanded="true" height="76" name="Performance" width="90" x="179" y="30"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="extract_macro" compatibility="5.3.013" expanded="true" height="60" name="Extract Macro" width="90" x="179" y="30"> <parameter key="macro" value="attributeCount"/> <parameter key="macro_type" value="number_of_attributes"/> <list key="additional_macros"/> </operator> <operator activated="true" class="provide_macro_as_log_value" compatibility="5.3.013" expanded="true" height="76" name="Provide attributeCount" width="90" x="313" y="30"> <parameter key="macro_name" value="attributeCount"/> </operator> <operator activated="true" class="log" compatibility="5.3.013" expanded="true" height="94" name="Log" width="90" x="447" y="75"> <list key="log"> <parameter key="attributeCount" value="operator.Provide attributeCount.value.macro_value"/> <parameter key="Performance" value="operator.Validation.value.performance"/> </list> </operator> <connect from_port="example set" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="training" to_op="Extract Macro" to_port="example set"/> <connect from_op="Validation" from_port="averagable 1" to_op="Log" to_port="through 2"/> <connect from_op="Extract Macro" from_port="example set" to_op="Provide attributeCount" to_port="through 1"/> <connect from_op="Provide attributeCount" from_port="through 1" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 2" to_port="performance"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_performance" spacing="90"/> </process> </operator> <operator activated="true" class="log_to_data" compatibility="5.3.013" expanded="true" height="94" name="Log to Data" width="90" x="380" y="30"> <parameter key="log_name" value="Log"/> </operator> <connect from_op="Retrieve Sonar" from_port="output" to_op="Forward Selection" to_port="example set"/> <connect from_op="Forward Selection" from_port="example set" to_op="Log to Data" to_port="through 1"/> <connect from_op="Log to Data" from_port="exampleSet" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
