<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.3.000" expanded="true" height="60" name="Retrieve sentim20k" width="90" x="45" y="120"> <parameter key="repository_entry" value="//Local Repository/Temp'training"/> </operator> <operator activated="true" class="set_role" compatibility="6.3.000" expanded="true" height="76" name="Set Role" width="90" x="179" y="255"> <parameter key="attribute_name" value="TempTag"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="polynomial_by_binomial_classification" compatibility="6.3.000" expanded="true" height="76" name="Polynomial by Binomial Classification" width="90" x="246" y="75"> <parameter key="classification_strategies" value="1 against 1"/> <process expanded="true"> <operator activated="true" class="x_validation" compatibility="5.1.002" expanded="true" name="Validation"> <description>A cross-validation evaluating a decision tree model.</description> <parameter key="leave_one_out" value="true"/> <process expanded="true"> <operator activated="true" class="support_vector_machine_libsvm" compatibility="6.3.000" expanded="true" name="SVM"> <list key="class_weights"/> </operator> <connect from_port="training" to_op="SVM" to_port="training set"/> <connect from_op="SVM" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="6.3.000" expanded="true" name="Apply Model"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="6.3.000" expanded="true" name="Performance"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_port="training set" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="model" to_port="model"/> <portSpacing port="source_training set" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> </process> </operator> <operator activated="true" class="apply_model" compatibility="6.3.000" expanded="true" height="76" name="Apply Model (2)" width="90" x="380" y="120"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="6.3.000" expanded="true" height="76" name="Performance (3)" width="90" x="514" y="30"/> <connect from_op="Retrieve sentim20k" from_port="output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Polynomial by Binomial Classification" to_port="training set"/> <connect from_op="Polynomial by Binomial Classification" from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_op="Polynomial by Binomial Classification" from_port="example set" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (3)" to_port="labelled data"/> <connect from_op="Performance (3)" from_port="performance" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
