Hi! I want to make a join between two tables, but the result looks like there's any value in common in the key attribute. I already checked that key attributes were of the same type (polynomial) and both are attributes. I dont know what else may be the problem. Thanks in advance.
This is my code:
<process version="6.4.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.4.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="read_csv" compatibility="6.4.000" expanded="true" height="60" name="Read CSV (5)" width="90" x="45" y="75">
<parameter key="csv_file" value="C:\Users\BI\Desktop\Beatriz\Cuantificacion quiebres\local 2029\Datos 2\2016.csv"/>
<parameter key="column_separators" value=","/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
