Hi I'm trying to use a Highchart Gauge, since it's not part of the standar deployment I create a process that writes the HTML.
Unfortunately it's not working.
I tried the same approach with a google gauge an it worked.
Can you help me?
<process version="6.4.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.4.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="text:create_document" compatibility="6.4.001" expanded="true" height="60" name="Create Document" width="90" x="514" y="30">
<parameter key="text" value="<html> <head> <script src="https://myurl:8443/RA/static/javascript/jquery/plugins/jquery.desaturate.js"></script> <script src="http://code.highcharts.com/highcharts.js"></script> <script src="http://code.highcharts.com/highcharts-more.js"></script> <script src="http://code.highcharts.com/modules/solid-gauge.js"></script> 	<script> $(function () { var gaugeOptions = { chart: { type: 'solidgauge' }, title: null, pane: { center: ['50%', '85%'], size: '140%', startAngle: -90, endAngle: 90, background: { backgroundColor: (Highcharts.theme && Highcharts.theme.background2) || '#EEE', innerRadius: '60%', outerRadius: '100%', shape: 'arc' } }, tooltip: { enabled: false }, // the value axis yAxis: { stops: [ [0.1, '#55BF3B'], // green [0.5, '#DDDF0D'], // yellow [0.9, '#DF5353'] // red ], lineWidth: 0, minorTickInterval: null, tickPixelInterval: 400, tickWidth: 0, title: { y: -70 }, labels: { y: 16 } }, plotOptions: { solidgauge: { dataLabels: { y: 5, borderWidth: 0, useHTML: true } } } }; // The speed gauge $('#container-speed').highcharts(Highcharts.merge(gaugeOptions, { yAxis: { min: 0, max: 100, title: { text: 'Objetivo' } }, credits: { enabled: false }, series: [{ name: 'Speed', data: [80], dataLabels: { format: '<div style="text-align:center"><span style="font-size:25px;color:' + ((Highcharts.theme && Highcharts.theme.contrastTextColor) || 'black') + '">{y}</span><br/>' + '<span style="font-size:12px;color:silver">km/h</span></div>' }, tooltip: { valueSuffix: ' km/h' } }] })); }); </script> </head> <body> <div style="width: 600px; height: 400px; margin: 0 auto"> 	<div id="container-speed" style="width: 300px; height: 200px; float: left"></div> 	<div id="container-rpm" style="width: 300px; height: 200px; float: left"></div> 	</div> </body> </html>"/>
<connect from_op="Create Document" from_port="output" to_port="result 1"/>
</process>
</process>
