<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.009"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.009" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data" compatibility="5.3.009" expanded="true" height="60" name="Generate Data" width="90" x="28" y="74"> <parameter key="number_of_attributes" value="16"/> </operator> <operator activated="true" class="loop" compatibility="5.3.009" expanded="true" height="76" name="Loop" width="90" x="313" y="75"> <parameter key="set_iteration_macro" value="true"/> <parameter key="macro_start_value" value="0"/> <parameter key="iterations" value="4"/> <process expanded="true"> <operator activated="true" class="generate_macro" compatibility="5.3.009" expanded="true" height="76" name="Generate Macro" width="90" x="112" y="30"> <list key="function_descriptions"> <parameter key="i_1" value="%{iteration}*3+1"/> <parameter key="i_2" value="%{iteration}*3+2"/> <parameter key="i_3" value="%{iteration}*3+3"/> </list> </operator> <operator activated="true" class="generate_aggregation" compatibility="5.3.009" expanded="true" height="76" name="Generate Aggregation" width="90" x="313" y="30"> <parameter key="attribute_name" value="a_sum_%{i_1}_%{i_2}_%{i_3}"/> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|att%{i_1}|att%{i_2}|att%{i_3}"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.3.009" expanded="true" height="76" name="Select Attributes" width="90" x="447" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="a_sum_%{i_1}_%{i_2}_%{i_3}"/> </operator> <connect from_port="input 1" to_op="Generate Macro" to_port="through 1"/> <connect from_op="Generate Macro" from_port="through 1" to_op="Generate Aggregation" to_port="example set input"/> <connect from_op="Generate Aggregation" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_op="Generate Data" from_port="output" to_op="Loop" to_port="input 1"/> <connect from_op="Loop" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.012"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.012" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_direct_mailing_data" compatibility="5.3.012" expanded="true" height="60" name="Generate Direct Mailing Data" width="90" x="45" y="30"/> <operator activated="true" class="generate_id" compatibility="5.3.012" expanded="true" height="76" name="Generate ID" width="90" x="112" y="210"/> <operator activated="true" class="rename_by_generic_names" compatibility="5.3.012" expanded="true" height="76" name="Rename by Generic Names" width="90" x="179" y="120"/> <operator activated="true" class="subprocess" compatibility="5.3.012" expanded="true" height="76" name="YourProcessingHere" width="90" x="246" y="30"> <process expanded="true"> <connect from_port="in 1" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="join" compatibility="5.3.012" expanded="true" height="76" name="Join" width="90" x="313" y="165"> <list key="key_attributes"/> </operator> <connect from_op="Generate Direct Mailing Data" from_port="output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Rename by Generic Names" to_port="example set input"/> <connect from_op="Rename by Generic Names" from_port="example set output" to_op="YourProcessingHere" to_port="in 1"/> <connect from_op="Rename by Generic Names" from_port="original" to_op="Join" to_port="right"/> <connect from_op="YourProcessingHere" from_port="out 1" to_op="Join" to_port="left"/> <connect from_op="Join" from_port="join" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
