Altair RISE
Nominate Yourself Now!
"How to generate attributes using attributes from two datasets (sources)"
bgracian
Hello! I am new with rapidminer, and i am taking the first steps with ETL processes. Now, i have found a problem that i don't know how to solve it. In particular, I am looking for a way to generating new attributes applying function expressions where I need to use attributes from two database tables (dataset1, dataset2), where one of the tables (dataset2) has attributes that i need to use to calculate new attributes in the other table (dataset1).
Tables have different number of rows, and need to calculate a particular value of att1 in dataset1 to apply as a constant to calculate new attribute.
dataset1
att1 att2 att3
row1 1.1 1.2 2.3
row2 1 2.2 3.3
row3 1 2.4 5.3
dataset2
att1 att2 att3
row1 1.1 2 3
row2 1.2 2 3
row3 1.3 2 3
row4 1.4 2 3
row5 1.6 2 3
row6 1.7 2 3
Using Generate attributes
new attribute (dataset1)
dataset1.att4 = dataset1.att1 * dataset2.att1
Is it possible to use attributes from other datasets to calculate new attributes in other dataset?
Best regards,
alberto
Generate Attributes
wessel
Based on your example, what should be the result?
Should I simply discard
row4 1.4 2 3
row5 1.6 2 3
row6 1.7 2 3
Best regards,
Wessel
Edit:
See process below, with join and generate attributes.
wessel
<process version="5.3.013">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="generate_data" compatibility="5.3.013" expanded="true" height="60" name="Generate Data" width="90" x="228" y="101">
<parameter key="number_examples" value="3"/>
<operator activated="true" class="generate_id" compatibility="5.3.013" expanded="true" height="76" name="Generate ID" width="90" x="453" y="122"/>
<operator activated="true" class="generate_data" compatibility="5.3.013" expanded="true" height="60" name="Generate Data (2)" width="90" x="223" y="203">
<parameter key="number_examples" value="5"/>
<operator activated="true" class="generate_id" compatibility="5.3.013" expanded="true" height="76" name="Generate ID (2)" width="90" x="415" y="272"/>
<operator activated="true" class="rename_by_replacing" compatibility="5.3.013" expanded="true" height="76" name="Rename by Replacing" width="90" x="547" y="420">
<parameter key="replace_what" value="$"/>
<parameter key="replace_by" value="_2"/>
<operator activated="true" class="join" compatibility="5.3.013" expanded="true" height="76" name="Join" width="90" x="573" y="216">
<list key="key_attributes"/>
<operator activated="true" class="generate_attributes" compatibility="5.3.013" expanded="true" height="76" name="Generate Attributes" width="90" x="735" y="162">
<parameter key="att1*att1_2" value="att1*att1_2"/>
</list>
<connect from_op="Generate Data" from_port="output" to_op="Generate ID" to_port="example set input"/>
<connect from_op="Generate ID" from_port="example set output" to_op="Join" to_port="left"/>
<connect from_op="Generate Data (2)" from_port="output" to_op="Generate ID (2)" to_port="example set input"/>
<connect from_op="Generate ID (2)" from_port="example set output" to_op="Rename by Replacing" to_port="example set input"/>
<connect from_op="Rename by Replacing" from_port="example set output" to_op="Join" to_port="right"/>
<connect from_op="Join" from_port="join" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/>
</process>
</process>
