I'm trying to make a text classification modeling and I'm using the following processes:
1)Read Excel
2)Data to documents
3)Process documents
4)Validation
The problem a get is in the validation process. I receive a mensage tha i don't have a label atribbute althought I have the following structure in my data::
Column1 Column2 Column3
ROW 1 ID (ID) attribute (text) LABEL(binomial)
To make a test I've put a SELECT ATRIBUTES operator after the Read Excel and I'm able to see the tree atributes. When I use the Select atributes operator after the Process Documents operator i canot select any atribute (the same occurs when i put after the Data to documents operators).
?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.2.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
<process expanded="true" height="449" width="681">
<operator activated="true" class="read_excel" compatibility="5.2.008" expanded="true" height="60" name="Read Excel" width="90" x="45" y="30">
<parameter key="excel_file" value="C:\Documents and Settings\igor.penna\Desktop\OFICIAL2.xlsx"/>
<parameter key="sheet_number" value="3"/>
<parameter key="imported_cell_range" value="A1:C41"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="0" value="ID.true.integer.id"/>
<parameter key="1" value="HISTORICO.true.text.attribute"/>
<parameter key="2" value="CLASSIFICACAO.true.binominal.label"/>
</list>
<parameter key="read_not_matching_values_as_missings" value="false"/>
<parameter key="datamanagement" value="double_sparse_array"/>
<operator activated="true" class="text:data_to_documents" compatibility="5.3.000" expanded="true" height="60" name="Data to Documents" width="90" x="45" y="165">
<list key="specify_weights"/>
<operator activated="true" class="text:process_documents" compatibility="5.3.000" expanded="true" height="94" name="Process Documents" width="90" x="45" y="300">
<parameter key="prune_below_absolute" value="2"/>
<parameter key="prune_above_absolute" value="999"/>
<process expanded="true" height="412" width="688">
<operator activated="true" class="text:transform_cases" compatibility="5.3.000" expanded="true" height="60" name="Transform Cases (2)" width="90" x="36" y="25"/>
<operator activated="true" class="text:replace_tokens" compatibility="5.3.000" expanded="true" height="60" name="Replace Tokens (2)" width="90" x="45" y="120">
<list key="replace_dictionary">
<parameter key="anv" value="aeronave"/>
<parameter key="nº" value="número"/>
</list>
<operator activated="true" class="text:tokenize" compatibility="5.3.000" expanded="true" height="60" name="Tokenize (2)" width="90" x="45" y="210"/>
<operator activated="true" class="text:filter_stopwords_dictionary" compatibility="5.3.000" expanded="true" height="76" name="Filter Stopwords (2)" width="90" x="45" y="300">
<parameter key="file" value="C:\Documents and Settings\igor.penna\Desktop\dicionario de exclusões.txt"/>
<operator activated="true" class="text:filter_by_length" compatibility="5.3.000" expanded="true" height="60" name="Filter Tokens (2)" width="90" x="246" y="30">
<parameter key="min_chars" value="2"/>
<parameter key="max_chars" value="999"/>
<connect from_port="document" to_op="Transform Cases (2)" to_port="document"/>
<connect from_op="Transform Cases (2)" from_port="document" to_op="Replace Tokens (2)" to_port="document"/>
<connect from_op="Replace Tokens (2)" from_port="document" to_op="Tokenize (2)" to_port="document"/>
<connect from_op="Tokenize (2)" from_port="document" to_op="Filter Stopwords (2)" to_port="document"/>
<connect from_op="Filter Stopwords (2)" from_port="document" to_op="Filter Tokens (2)" to_port="document"/>
<connect from_op="Filter Tokens (2)" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="x_validation" compatibility="5.2.008" expanded="true" height="112" name="Validation" width="90" x="380" y="210">
<process expanded="true" height="412" width="319">
<operator activated="false" class="k_nn" compatibility="5.2.008" expanded="true" height="76" name="k-NN" width="90" x="112" y="30">
<parameter key="k" value="3"/>
<parameter key="measure_types" value="NumericalMeasures"/>
<parameter key="numerical_measure" value="CosineSimilarity"/>
<connect from_port="training" to_op="k-NN" to_port="training set"/>
<connect from_op="k-NN" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<operator activated="false" class="apply_model" compatibility="5.2.008" expanded="true" height="76" name="Apply Model" width="90" x="112" y="30">
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Apply Model" from_port="labelled data" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<connect from_port="input 1" to_op="Read Excel" to_port="file"/>
<connect from_op="Read Excel" from_port="output" to_op="Data to Documents" to_port="example set"/>
<connect from_op="Data to Documents" from_port="documents" to_op="Process Documents" to_port="documents 1"/>
<connect from_op="Process Documents" from_port="example set" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="model" to_port="result 1"/>
</process>
</process>
Thank you
