<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.012"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.012" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="5.3.012" expanded="true" height="60" name="Retrieve Iris" width="90" x="112" y="75"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="set_macro" compatibility="5.3.012" expanded="true" height="76" name="Set Macro" width="90" x="246" y="75"> <parameter key="macro" value="ValidationCounter"/> <parameter key="value" value="1"/> </operator> <operator activated="true" class="x_validation" compatibility="5.3.012" expanded="true" height="112" name="Validation" width="90" x="380" y="120"> <description>Copyright Andrew Chisholm 2013Information Gain Ltd</description> <process expanded="true"> <operator activated="true" class="decision_tree" compatibility="5.0.000" expanded="true" height="76" name="Decision Tree" width="90" x="45" y="30"/> <connect from_port="training" to_op="Decision Tree" to_port="training set"/> <connect from_op="Decision Tree" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="materialize_data" compatibility="5.3.012" expanded="true" height="76" name="Materialize Data" width="90" x="45" y="120"/> <operator activated="true" class="apply_model" compatibility="5.0.000" expanded="true" height="76" name="Apply Model" width="90" x="179" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.0.000" expanded="true" height="76" name="Performance" width="90" x="313" y="30"/> <operator activated="true" class="remember" compatibility="5.3.012" expanded="true" height="60" name="Remember (3)" width="90" x="313" y="255"> <parameter key="name" value="test_%{ValidationCounter}"/> <parameter key="io_object" value="ExampleSet"/> </operator> <operator activated="true" class="generate_macro" compatibility="5.3.012" expanded="true" height="76" name="Generate Macro" width="90" x="514" y="30"> <list key="function_descriptions"> <parameter key="ValidationCounter" value="%{ValidationCounter}+1"/> </list> </operator> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Materialize Data" to_port="example set input"/> <connect from_op="Materialize Data" from_port="example set output" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_op="Generate Macro" to_port="through 1"/> <connect from_op="Performance" from_port="example set" to_op="Remember (3)" to_port="store"/> <connect from_op="Generate Macro" from_port="through 1" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="loop" compatibility="5.3.012" expanded="true" height="112" name="Loop" width="90" x="581" y="120"> <parameter key="set_iteration_macro" value="true"/> <parameter key="iterations" value="10"/> <process expanded="true"> <operator activated="true" class="recall" compatibility="5.3.012" expanded="true" height="60" name="Recall" width="90" x="179" y="120"> <parameter key="name" value="test_%{iteration}"/> <parameter key="io_object" value="ExampleSet"/> </operator> <connect from_port="input 1" to_port="output 1"/> <connect from_port="input 2" to_port="output 2"/> <connect from_op="Recall" from_port="result" to_port="output 3"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="source_input 3" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> <portSpacing port="sink_output 3" spacing="0"/> <portSpacing port="sink_output 4" spacing="0"/> </process> </operator> <connect from_op="Retrieve Iris" from_port="output" to_op="Set Macro" to_port="through 1"/> <connect from_op="Set Macro" from_port="through 1" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="training" to_op="Loop" to_port="input 1"/> <connect from_op="Validation" from_port="averagable 1" to_op="Loop" to_port="input 2"/> <connect from_op="Loop" from_port="output 3" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
