<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.013"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <parameter key="parallelize_main_process" value="false"/> <process expanded="true"> <operator activated="true" class="imageprocessing:open_color_image" compatibility="1.4.001" expanded="true" height="60" name="Open Color Image" width="90" x="45" y="75"> <parameter key="filename" value="C:\temp\logo.png"/> <parameter key="set_mask" value="false"/> <parameter key="force_conversion" value="true"/> </operator> <operator activated="true" class="reporting:generate_report" compatibility="5.3.000" expanded="true" height="76" name="Generate Report" width="90" x="179" y="75"> <parameter key="report_name" value="report"/> <parameter key="format" value="HTML"/> <parameter key="report_to_repository" value="false"/> <parameter key="html_output_directory" value="C:\temp"/> <parameter key="html_image_format" value="png"/> <parameter key="image_col_span" value="8"/> <parameter key="image_row_span" value="17"/> <parameter key="page_size" value="A4"/> <parameter key="page_format" value="portrait"/> <parameter key="template_type" value="none"/> <parameter key="image_alignment" value="aspect_ratio"/> <parameter key="set_background_color" value="false"/> <parameter key="background_color" value="255,255,255"/> <parameter key="page_width" value="595"/> <parameter key="page_height" value="842"/> <parameter key="top_page_margin" value="36"/> <parameter key="bottom_page_margin" value="36"/> <parameter key="left_page_margin" value="36"/> <parameter key="right_page_margin" value="36"/> <parameter key="section_one_font_size" value="12.0"/> <parameter key="section_one_font_style_bold" value="false"/> <parameter key="section_one_font_style_italic" value="false"/> <parameter key="section_one_font_style_underline" value="false"/> <parameter key="section_one_font_style_strikethrough" value="false"/> <parameter key="section_one_font_color" value="0,0,0"/> <parameter key="section_two_font_size" value="12.0"/> <parameter key="section_two_font_style_bold" value="false"/> <parameter key="section_two_font_style_italic" value="false"/> <parameter key="section_two_font_style_underline" value="false"/> <parameter key="section_two_font_style_strikethrough" value="false"/> <parameter key="section_two_font_color" value="0,0,0"/> <parameter key="section_three_font_size" value="12.0"/> <parameter key="section_three_font_style_bold" value="false"/> <parameter key="section_three_font_style_italic" value="false"/> <parameter key="section_three_font_style_underline" value="false"/> <parameter key="section_three_font_style_strikethrough" value="false"/> <parameter key="section_three_font_color" value="0,0,0"/> <parameter key="section_four_font_size" value="12.0"/> <parameter key="section_four_font_style_bold" value="false"/> <parameter key="section_four_font_style_italic" value="false"/> <parameter key="section_four_font_style_underline" value="false"/> <parameter key="section_four_font_style_strikethrough" value="false"/> <parameter key="section_four_font_color" value="0,0,0"/> <parameter key="section_five_font_size" value="12.0"/> <parameter key="section_five_font_style_bold" value="false"/> <parameter key="section_five_font_style_italic" value="false"/> <parameter key="section_five_font_style_underline" value="false"/> <parameter key="section_five_font_style_strikethrough" value="false"/> <parameter key="section_five_font_color" value="0,0,0"/> <parameter key="text_content_font_size" value="12.0"/> <parameter key="text_content_font_style_bold" value="false"/> <parameter key="text_content_font_style_italic" value="false"/> <parameter key="text_content_font_style_underline" value="false"/> <parameter key="text_content_font_style_strikethrough" value="false"/> <parameter key="text_content_font_color" value="0,0,0"/> <parameter key="system_fonts" value="false"/> <parameter key="directory_fonts" value="false"/> <parameter key="table_column_number" value="8"/> <parameter key="table_header_color" value="128,128,128"/> <parameter key="table_row_color_one" value="255,255,255"/> <parameter key="table_row_color_two" value="192,192,192"/> </operator> <operator activated="true" class="reporting:report" compatibility="5.3.000" expanded="true" height="60" name="Report" width="90" x="313" y="75"> <parameter key="report_name" value="report"/> <parameter key="report_item_header" value="Here is an image:"/> <parameter key="specified" value="true"/> <parameter key="reportable_type" value="ColorImagePlus"/> <parameter key="renderer_name" value="ImagePlus"/> <list key="parameters"/> <parameter key="image_width" value="800"/> <parameter key="image_height" value="600"/> </operator> <connect from_op="Open Color Image" from_port="color image plus" to_op="Generate Report" to_port="through 1"/> <connect from_op="Generate Report" from_port="through 1" to_op="Report" to_port="reportable in"/> <connect from_op="Report" from_port="reportable out" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
