<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.013"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="subprocess" compatibility="5.3.013" expanded="true" height="76" name="Subprocess" width="90" x="112" y="75"> <process expanded="true"> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.013" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="111" y="30"> <list key="attribute_values"> <parameter key="user" value=""user1""/> <parameter key="date" value=""2013-08-01""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.013" expanded="true" height="60" name="Generate Data by User Specification (2)" width="90" x="112" y="120"> <list key="attribute_values"> <parameter key="user" value=""user1""/> <parameter key="date" value=""2013-08-08""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.013" expanded="true" height="60" name="Generate Data by User Specification (3)" width="90" x="112" y="210"> <list key="attribute_values"> <parameter key="user" value=""user2""/> <parameter key="date" value=""2013-08-01""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.013" expanded="true" height="60" name="Generate Data by User Specification (4)" width="90" x="112" y="300"> <list key="attribute_values"> <parameter key="user" value=""user2""/> <parameter key="date" value=""2013-08-06""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="append" compatibility="5.3.013" expanded="true" height="130" name="Append" width="90" x="380" y="75"/> <operator activated="true" class="nominal_to_date" compatibility="5.3.013" expanded="true" height="76" name="Nominal to Date" width="90" x="581" y="75"> <parameter key="attribute_name" value="date"/> <parameter key="date_format" value="yyyy-MM-dd"/> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Append" to_port="example set 1"/> <connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Append" to_port="example set 2"/> <connect from_op="Generate Data by User Specification (3)" from_port="output" to_op="Append" to_port="example set 3"/> <connect from_op="Generate Data by User Specification (4)" from_port="output" to_op="Append" to_port="example set 4"/> <connect from_op="Append" from_port="merged set" to_op="Nominal to Date" to_port="example set input"/> <connect from_op="Nominal to Date" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="loop_values" compatibility="5.3.013" expanded="true" height="76" name="Loop Values" width="90" x="112" y="165"> <parameter key="attribute" value="user"/> <process expanded="true"> <operator activated="true" class="filter_examples" compatibility="5.3.013" expanded="true" height="76" name="Filter Examples" width="90" x="179" y="75"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="user=%{loop_value}"/> </operator> <operator activated="true" class="series:lag_series" compatibility="5.3.000" expanded="true" height="76" name="Lag Series" width="90" x="380" y="75"> <list key="attributes"> <parameter key="date" value="1"/> </list> </operator> <connect from_port="example set" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Lag Series" to_port="example set input"/> <connect from_op="Lag Series" from_port="example set output" to_port="out 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="5.3.013" expanded="true" height="76" name="Append (2)" width="90" x="112" y="255"/> <operator activated="true" class="rename" compatibility="5.3.013" expanded="true" height="76" name="Rename" width="90" x="246" y="75"> <parameter key="old_name" value="date-1"/> <parameter key="new_name" value="date1"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="generate_attributes" compatibility="5.3.013" expanded="true" height="76" name="Generate Attributes" width="90" x="246" y="165"> <list key="function_descriptions"> <parameter key="diff" value="date_diff(date1,date)/1000/3600/24"/> </list> </operator> <operator activated="true" class="select_attributes" compatibility="5.3.013" expanded="true" height="76" name="Select Attributes" width="90" x="246" y="255"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|user|diff"/> </operator> <connect from_op="Subprocess" from_port="out 1" to_op="Loop Values" to_port="example set"/> <connect from_op="Loop Values" from_port="out 1" to_op="Append (2)" to_port="example set 1"/> <connect from_op="Append (2)" from_port="merged set" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
