Can we count the number of particles hitting a boundary or a wall? If yes can you please refer me to a particular source to look at?
Is it possible to generate same set of random injections on EDEM from the factory? I want my simulations as repeatable as possible.
Thanks,
Kiran
Hi Kiran,
You can use the dynamic block factory to record a set of particle and then repeat the placement of these. The dynamic block factory is covered in the e-learning 'EDEM Creator: Material Block Dynamic' lesson:
https://learn.altair.com/course/view.php?id=147
We can count contacts with particles and walls but these are instantaneous contacts so it depends on your save interval as to how good a resolution of results you need for this. There are also API options for this such as:
https://community.altair.com/community/en/edem-api-contact-model-example-removing-particles?id=kb_article_view&sysparm_article=KB0122028
This case counts and removes particles but the code could be modified.
Regards
Stephen
