Beware Generate Macro's result truncation!
New Altair Community Member
Updated by Jocelyn
To whom it may interest
In the following process's output, why is a != b ?
<?xml version="1.0" encoding="UTF-8" standalone="no"?>Because when Generate Macro converts numeric results to strings (as it must) it truncates them according to rapidminer.general.fractiondigits.numbers. You either have to use Set Macro, or change your preferences. Simply quoting doesn't work either, because Generate Macros, unlike Generate Attributes, tries to convert string->number->string.
<process version="5.3.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="generate_macro" compatibility="5.3.008" expanded="true" height="60" name="Generate Macro" width="90" x="45" y="30">
<parameter key="eps" value="1e-6"/>
</list>
<operator activated="true" class="generate_data_user_specification" compatibility="5.3.008" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="246" y="30">
<list key="attribute_values">
<parameter key="a" value="1e6*1e-6"/>
<parameter key="b" value="1e6*%{eps}"/>
</list>
<connect from_op="Generate Data by User Specification" from_port="output" to_port="result 1"/>
</process>
</process>
