<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data" compatibility="5.3.008" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"/> <operator activated="true" class="generate_id" compatibility="5.3.008" expanded="true" height="76" name="Generate ID" width="90" x="179" y="30"/> <operator activated="true" class="generate_attributes" compatibility="5.3.008" expanded="true" height="76" name="Generate Attributes" width="90" x="313" y="30"> <list key="function_descriptions"> <parameter key="x" value="sin(2*pi*(id-1)/100)"/> </list> </operator> <operator activated="true" class="select_attributes" compatibility="5.3.008" expanded="true" height="76" name="Select Attributes" width="90" x="447" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="x"/> <parameter key="attributes" value="|t|x"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="materialize_data" compatibility="5.3.008" expanded="true" height="76" name="Materialize Data" width="90" x="581" y="30"/> <operator activated="true" class="materialize_data" compatibility="5.3.008" expanded="true" height="76" name="Materialize Data (2)" width="90" x="45" y="165"/> <operator activated="true" class="materialize_data" compatibility="5.3.008" expanded="true" height="76" name="Materialize Data (3)" width="90" x="45" y="300"/> <operator activated="true" class="series:data_to_series" compatibility="5.3.000" expanded="true" height="60" name="Data To Series (3)" width="90" x="179" y="300"> <parameter key="series_attribute" value="x"/> </operator> <operator activated="true" class="series:discrete_fourier_transformation" compatibility="5.3.000" expanded="true" height="60" name="Discrete Fourier Transformation (2)" width="90" x="313" y="300"/> <operator activated="true" class="series:series_to_data" compatibility="5.3.000" expanded="true" height="60" name="Series To Data" width="90" x="447" y="255"/> <operator activated="true" class="series:data_to_series" compatibility="5.3.000" expanded="true" height="60" name="Data To Series (2)" width="90" x="447" y="345"> <parameter key="series_attribute" value="DFT(x)_dim_1"/> </operator> <operator activated="true" class="series:discrete_fourier_transformation" compatibility="5.3.000" expanded="true" height="60" name="Discrete Fourier Transformation (3)" width="90" x="581" y="300"> <parameter key="direction" value="frequency --> time"/> </operator> <operator activated="true" class="series:series_to_data" compatibility="5.3.000" expanded="true" height="60" name="Series To Data (3)" width="90" x="715" y="300"/> <operator activated="true" class="series:data_to_series" compatibility="5.3.000" expanded="true" height="60" name="Data To Series" width="90" x="179" y="165"> <parameter key="series_attribute" value="x"/> </operator> <operator activated="true" class="series:discrete_fourier_transformation" compatibility="5.3.000" expanded="true" height="60" name="Discrete Fourier Transformation" width="90" x="313" y="165"/> <operator activated="true" class="series:discrete_fourier_transformation" compatibility="5.3.000" expanded="true" height="60" name="Discrete Fourier Transformation (4)" width="90" x="581" y="165"> <parameter key="direction" value="frequency --> time"/> </operator> <operator activated="true" class="series:series_to_data" compatibility="5.3.000" expanded="true" height="60" name="Series To Data (2)" width="90" x="715" y="165"/> <connect from_op="Generate Data" from_port="output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Materialize Data" to_port="example set input"/> <connect from_op="Materialize Data" from_port="example set output" to_port="result 1"/> <connect from_op="Materialize Data" from_port="original" to_op="Materialize Data (2)" to_port="example set input"/> <connect from_op="Materialize Data (2)" from_port="example set output" to_op="Data To Series" to_port="example set"/> <connect from_op="Materialize Data (2)" from_port="original" to_op="Materialize Data (3)" to_port="example set input"/> <connect from_op="Materialize Data (3)" from_port="example set output" to_op="Data To Series (3)" to_port="example set"/> <connect from_op="Data To Series (3)" from_port="series" to_op="Discrete Fourier Transformation (2)" to_port="series"/> <connect from_op="Discrete Fourier Transformation (2)" from_port="series" to_op="Series To Data" to_port="series"/> <connect from_op="Series To Data" from_port="example set" to_op="Data To Series (2)" to_port="example set"/> <connect from_op="Data To Series (2)" from_port="series" to_op="Discrete Fourier Transformation (3)" to_port="series"/> <connect from_op="Discrete Fourier Transformation (3)" from_port="series" to_op="Series To Data (3)" to_port="series"/> <connect from_op="Series To Data (3)" from_port="example set" to_port="result 3"/> <connect from_op="Data To Series" from_port="series" to_op="Discrete Fourier Transformation" to_port="series"/> <connect from_op="Discrete Fourier Transformation" from_port="series" to_op="Discrete Fourier Transformation (4)" to_port="series"/> <connect from_op="Discrete Fourier Transformation (4)" from_port="series" to_op="Series To Data (2)" to_port="series"/> <connect from_op="Series To Data (2)" from_port="example set" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="18"/> <portSpacing port="sink_result 2" spacing="126"/> <portSpacing port="sink_result 3" spacing="90"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data" compatibility="5.3.008" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"/> <operator activated="true" class="generate_id" compatibility="5.3.008" expanded="true" height="76" name="Generate ID" width="90" x="179" y="30"/> <operator activated="true" class="generate_attributes" compatibility="5.3.008" expanded="true" height="76" name="Generate Attributes" width="90" x="313" y="30"> <list key="function_descriptions"> <parameter key="t" value="id-1"/> <parameter key="x" value="sin(2*pi*t/100)"/> </list> </operator> <operator activated="true" class="select_attributes" compatibility="5.3.008" expanded="true" height="76" name="Select Attributes" width="90" x="447" y="30"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|t|x"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="set_role" compatibility="5.3.008" expanded="true" height="76" name="Set Role" width="90" x="581" y="30"> <parameter key="attribute_name" value="x"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="fourier_transformation" compatibility="5.3.008" expanded="true" height="76" name="Fourier Transformation" width="90" x="715" y="30"/> <connect from_op="Generate Data" from_port="output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Fourier Transformation" to_port="example set input"/> <connect from_op="Fourier Transformation" from_port="example set output" to_port="result 1"/> <connect from_op="Fourier Transformation" from_port="original" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
