Run the following process (with series processing extension installed):
<process version="5.3.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="generate_data" compatibility="5.3.008" expanded="true" height="60" name="Generate Data" width="90" x="45" y="75">
<parameter key="number_of_attributes" value="1"/>
<operator activated="true" class="generate_id" compatibility="5.3.008" expanded="true" height="76" name="Generate ID" width="90" x="179" y="75"/>
<operator activated="true" class="generate_attributes" compatibility="5.3.008" expanded="true" height="76" name="Generate Attributes" width="90" x="313" y="75">
<parameter key="x" value="sin(2*pi*((id-1)/100 + 0.25))"/>
</list>
<operator activated="true" class="series:data_to_series" compatibility="5.3.000" expanded="true" height="60" name="Data To Series" width="90" x="447" y="75">
<parameter key="series_attribute" value="x"/>
<operator activated="true" class="series:discrete_fourier_transformation" compatibility="5.3.000" expanded="true" height="60" name="Discrete Fourier Transformation" width="90" x="581" y="75"/>
<operator activated="false" class="series:series_to_data" compatibility="5.3.000" expanded="true" height="60" name="Series To Data" width="90" x="715" y="165"/>
<connect from_op="Generate Data" from_port="output" to_op="Generate ID" to_port="example set input"/>
<connect from_op="Generate ID" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_op="Data To Series" to_port="example set"/>
<connect from_op="Data To Series" from_port="series" to_op="Discrete Fourier Transformation" to_port="series"/>
<connect from_op="Discrete Fourier Transformation" from_port="series" to_port="result 1"/>
</process>
</process>
Select plot view.
Select dim_1
Select Complex value type: imaginary
At this point, RM hangs for me (win 7).
