I was performing coupled Ansys Fluent-EDEM tutorial number 3 where the aim is to study heat transfer of particles in a fluidised bed. I was planning on using my own geometry for this case.
To design my own mesh and run a coupled simulation I have a few questions.
1. In Ansys Fluent the NS equations are solved for each fluid volume, so if I have an hollow cylinder as the mesh I think there would be problems in the solution, so what approach should I be taking when I design a mesh for a coupled simulation.
2. Where can I read about EDEM's solver logic for DEM.
In short do I need to have a solid or a hollow mesh to run a coupled solution for fluidised bed of different dimension. I hope my question is clear, thanks in advance
Thanks.
Kiran
