"What are the calculations of a neural network output?"
User: "tigerwoods"
New Altair Community Member
Updated by Jocelyn
I'm using a neural network to predict a continuous variable. My model is the following:
Node 1 (Sigmoid)
A -0,311
B -0,183
C -0,391
D -1,448
Bias -2,001
Node 2 (Sigmoid)
A 0,124
B -0,428
C -0,291
D -3,069
Bias -2,814
Node 3 (Sigmoid)
A -0,924
B -1,104
C -0,006
D -0,421
Bias -1,557
Output
Regression (Linear)
Node 1 -0,583
Node 2 -2,161
Node 3 0,88
Threshold 0,533
With this model I want to predict new values, imagine for
A -1,834944684
B -1,754940513
C -0,312412486
D -1,275034298
Rapidminer gives me the result: 15,47%, but I'm not abble to arrive to this solution by the calculations.
My calculations are:
Value of Node 1 = 1/(1+exp(-(bias+sumproduct(coeficients in node 1; new values for A B C D)))
And I proceed similary for the other 2 nodes.
Value of output:
0,533 + (-0,583 )* value of node1 + (-2,161)*value of node2 + 0,88*value of node3
My result is: -88,8%
Can you help me to find my error in calculations?
Thank you very much.
Rufo
1 - 1 of 11
    User: "MariusHelf"
    Hi Rufo,
    maybe this is caused by a bug in the Neural Net operator that has already been fixed and will be included in the next release. Does the Neural Net work as expected if you apply it on the same data on which you trained it? If yes, then your problem will be fixed with the next release. Otherwise we will have to investigate further.
    Best regards,
    Marius
