<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.009"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.009" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="handle_exception" compatibility="5.3.009" expanded="true" height="76" name="Handle Exception" width="90" x="112" y="30"> <process expanded="true"> <operator activated="true" class="loop" compatibility="5.3.009" expanded="true" height="76" name="Loop" width="90" x="112" y="30"> <parameter key="set_iteration_macro" value="true"/> <parameter key="iterations" value="2147483647"/> <process expanded="true"> <operator activated="true" class="print_to_console" compatibility="5.3.009" expanded="true" height="76" name="Print to Console" width="90" x="112" y="30"> <parameter key="log_value" value="%{iteration}"/> </operator> <operator activated="true" class="branch" compatibility="5.3.009" expanded="true" height="76" name="Branch" width="90" x="407" y="30"> <parameter key="condition_type" value="expression"/> <parameter key="condition_value" value="%{iteration}>10"/> <process expanded="true"> <operator activated="true" class="throw_exception" compatibility="5.3.009" expanded="true" height="76" name="Throw Exception" width="90" x="168" y="30"> <parameter key="message" value="%{iteration} > 10"/> </operator> <connect from_port="condition" to_op="Throw Exception" to_port="through 1"/> <connect from_op="Throw Exception" from_port="through 1" to_port="input 1"/> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> <portSpacing port="sink_input 2" spacing="0"/> </process> <process expanded="true"> <portSpacing port="source_condition" spacing="0"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_input 1" spacing="0"/> <portSpacing port="sink_input 2" spacing="0"/> </process> </operator> <connect from_port="input 1" to_op="Print to Console" to_port="through 1"/> <connect from_op="Print to Console" from_port="through 1" to_op="Branch" to_port="condition"/> <connect from_op="Branch" from_port="input 1" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_port="in 1" to_op="Loop" to_port="input 1"/> <connect from_op="Loop" from_port="output 1" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> <process expanded="true"> <connect from_port="in 1" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <connect from_port="input 1" to_op="Handle Exception" to_port="in 1"/> <connect from_op="Handle Exception" from_port="out 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
