<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.005"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.005" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="text:create_document" compatibility="5.3.000" expanded="true" height="60" name="Create Document" width="90" x="112" y="75"> <parameter key="text" value="This is to initialize the content of Remember/Recall operators. "/> </operator> <operator activated="true" class="remember" compatibility="5.3.005" expanded="true" height="60" name="Remember (2)" width="90" x="246" y="75"> <parameter key="name" value="doc"/> <parameter key="io_object" value="Document"/> </operator> <operator activated="true" class="loop_files" compatibility="5.3.005" expanded="true" height="60" name="Loop Files" width="90" x="380" y="165"> <parameter key="directory" value="/Users/mdc/Texts"/> <process expanded="true"> <operator activated="true" class="text:read_document" compatibility="5.3.000" expanded="true" height="60" name="Read Document (2)" width="90" x="112" y="120"> <parameter key="file" value="%{file_path}"/> </operator> <operator activated="true" class="recall" compatibility="5.3.005" expanded="true" height="60" name="Recall" width="90" x="112" y="30"> <parameter key="name" value="doc"/> <parameter key="io_object" value="Document"/> </operator> <operator activated="true" class="text:combine_documents" compatibility="5.3.000" expanded="true" height="94" name="Combine Documents (2)" width="90" x="313" y="120"/> <operator activated="true" class="remember" compatibility="5.3.005" expanded="true" height="60" name="Remember" width="90" x="447" y="120"> <parameter key="name" value="doc"/> <parameter key="io_object" value="Document"/> </operator> <connect from_op="Read Document (2)" from_port="output" to_op="Combine Documents (2)" to_port="documents 2"/> <connect from_op="Recall" from_port="result" to_op="Combine Documents (2)" to_port="documents 1"/> <connect from_op="Combine Documents (2)" from_port="document" to_op="Remember" to_port="store"/> <portSpacing port="source_file object" spacing="0"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> </process> </operator> <operator activated="true" class="recall" compatibility="5.3.005" expanded="true" height="60" name="Recall (2)" width="90" x="514" y="75"> <parameter key="name" value="doc"/> <parameter key="io_object" value="Document"/> </operator> <operator activated="true" class="text:write_document" compatibility="5.3.000" expanded="true" height="76" name="Write Document" width="90" x="648" y="75"> <parameter key="file" value="/Users/matthewgarong/concatenated_text.txt"/> </operator> <connect from_op="Create Document" from_port="output" to_op="Remember (2)" to_port="store"/> <connect from_op="Recall (2)" from_port="result" to_op="Write Document" to_port="document"/> <connect from_op="Write Document" from_port="document" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
