Jul 15, 2013 6:50:55 AM com.rapidminer.Process loadInitialDataINFO: Loading initial data.Jul 15, 2013 6:50:57 AM com.rapidminer.Process saveResultsINFO: Saving results.Jul 15, 2013 6:50:57 AM com.rapidminer.Process runINFO: Process finished successfully after 1 sException in thread "UpdateQueue-documentation_update_queue" java.lang.OutOfMemoryError: PermGen space at java.lang.ClassLoader.findBootstrapClass(Native Method) at java.lang.ClassLoader.findBootstrapClassOrNull(ClassLoader.java:926) at java.lang.ClassLoader.loadClass(ClassLoader.java:297) at java.lang.ClassLoader.loadClass(ClassLoader.java:295) at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301) at java.lang.ClassLoader.loadClass(ClassLoader.java:247) at com.sun.org.apache.xalan.internal.utils.ObjectFactory.findProviderClass(ObjectFactory.java:587) at com.sun.org.apache.xalan.internal.utils.ObjectFactory.findProviderClass(ObjectFactory.java:542) at com.sun.org.apache.xml.internal.serializer.SerializerFactory.getSerializer(SerializerFactory.java:126) at com.sun.org.apache.xml.internal.serializer.ToUnknownStream.initStreamOutput(ToUnknownStream.java:1012) at com.sun.org.apache.xml.internal.serializer.ToUnknownStream.emitFirstTag(ToUnknownStream.java:1076) at com.sun.org.apache.xml.internal.serializer.ToUnknownStream.flush(ToUnknownStream.java:1236) at com.sun.org.apache.xml.internal.serializer.ToUnknownStream.startElement(ToUnknownStream.java:497) at com.sun.org.apache.xml.internal.serializer.ToUnknownStream.startElement(ToUnknownStream.java:467) at GregorSamsa.template$dot$0() at GregorSamsa.applyTemplates() at GregorSamsa.transform() at com.sun.org.apache.xalan.internal.xsltc.runtime.AbstractTranslet.transform(AbstractTranslet.java:605) at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(TransformerImpl.java:725) at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(TransformerImpl.java:336) at com.rapidminer.gui.OperatorDocToHtmlConverter.convert(OperatorDocToHtmlConverter.java:99) at com.rapidminer.gui.OperatorDocumentationBrowser.parseXmlAndReturnHtml(OperatorDocumentationBrowser.java:192) at com.rapidminer.gui.OperatorDocumentationBrowser.access$200(OperatorDocumentationBrowser.java:85) at com.rapidminer.gui.OperatorDocumentationBrowser$1.run(OperatorDocumentationBrowser.java:325) at com.rapidminer.gui.tools.UpdateQueue.run(UpdateQueue.java:81)Exception in thread "AWT-EventQueue-0" java.lang.OutOfMemoryError: PermGen space at java.lang.ClassLoader.findBootstrapClass(Native Method) at java.lang.ClassLoader.findBootstrapClassOrNull(ClassLoader.java:926) at java.lang.ClassLoader.loadClass(ClassLoader.java:297) at java.lang.ClassLoader.loadClass(ClassLoader.java:295) at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301) at java.lang.ClassLoader.loadClass(ClassLoader.java:247) at java.lang.ClassLoader.defineClass1(Native Method) at java.lang.ClassLoader.defineClassCond(ClassLoader.java:631) at java.lang.ClassLoader.defineClass(ClassLoader.java:615) at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:141) at java.net.URLClassLoader.defineClass(URLClassLoader.java:283) at java.net.URLClassLoader.access$000(URLClassLoader.java:58) at java.net.URLClassLoader$1.run(URLClassLoader.java:197) at java.security.AccessController.doPrivileged(Native Method) at java.net.URLClassLoader.findClass(URLClassLoader.java:190) at java.lang.ClassLoader.loadClass(ClassLoader.java:306) at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301) at java.lang.ClassLoader.loadClass(ClassLoader.java:247) at com.rapidminer.gui.look.ui.MenuUI$MenuMouseHandler.mouseEntered(MenuUI.java:62) at java.awt.AWTEventMulticaster.mouseEntered(AWTEventMulticaster.java:283) at java.awt.AWTEventMulticaster.mouseEntered(AWTEventMulticaster.java:282) at java.awt.Component.processMouseEvent(Component.java:6423) at javax.swing.JComponent.processMouseEvent(JComponent.java:3275) at java.awt.Component.processEvent(Component.java:6179) at java.awt.Container.processEvent(Container.java:2083) at java.awt.Component.dispatchEventImpl(Component.java:4776) at java.awt.Container.dispatchEventImpl(Container.java:2141) at java.awt.Component.dispatchEvent(Component.java:4604) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4619) at java.awt.LightweightDispatcher.trackMouseEnterExit(Container.java:4408) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4262) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4210)Exception in thread "AWT-EventQueue-0" java.lang.OutOfMemoryError: PermGen space at java.lang.ClassLoader.findBootstrapClass(Native Method) at java.lang.ClassLoader.findBootstrapClassOrNull(ClassLoader.java:926) at java.lang.ClassLoader.loadClass(ClassLoader.java:297) at java.lang.ClassLoader.loadClass(ClassLoader.java:295) at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301) at java.lang.ClassLoader.loadClass(ClassLoader.java:247) at java.lang.ClassLoader.defineClass1(Native Method) at java.lang.ClassLoader.defineClassCond(ClassLoader.java:631) at java.lang.ClassLoader.defineClass(ClassLoader.java:615) at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:141) at java.net.URLClassLoader.defineClass(URLClassLoader.java:283) at java.net.URLClassLoader.access$000(URLClassLoader.java:58) at java.net.URLClassLoader$1.run(URLClassLoader.java:197) at java.security.AccessController.doPrivileged(Native Method) at java.net.URLClassLoader.findClass(URLClassLoader.java:190) at java.lang.ClassLoader.loadClass(ClassLoader.java:306) at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301) at java.lang.ClassLoader.loadClass(ClassLoader.java:247) at com.rapidminer.gui.look.ui.MenuUI$MenuMouseHandler.mouseEntered(MenuUI.java:62) at java.awt.AWTEventMulticaster.mouseEntered(AWTEventMulticaster.java:283) at java.awt.AWTEventMulticaster.mouseEntered(AWTEventMulticaster.java:282) at java.awt.Component.processMouseEvent(Component.java:6423) at javax.swing.JComponent.processMouseEvent(JComponent.java:3275) at java.awt.Component.processEvent(Component.java:6179) at java.awt.Container.processEvent(Container.java:2083) at java.awt.Component.dispatchEventImpl(Component.java:4776) at java.awt.Container.dispatchEventImpl(Container.java:2141) at java.awt.Component.dispatchEvent(Component.java:4604) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4619) at java.awt.LightweightDispatcher.trackMouseEnterExit(Container.java:4408) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4262) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4210)Exception in thread "AWT-EventQueue-0" java.lang.OutOfMemoryError: PermGen space at java.lang.ClassLoader.findBootstrapClass(Native Method) at java.lang.ClassLoader.findBootstrapClassOrNull(ClassLoader.java:926) at java.lang.ClassLoader.loadClass(ClassLoader.java:297) at java.lang.ClassLoader.loadClass(ClassLoader.java:295) at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301) at java.lang.ClassLoader.loadClass(ClassLoader.java:247) at java.lang.ClassLoader.defineClass1(Native Method) at java.lang.ClassLoader.defineClassCond(ClassLoader.java:631) at java.lang.ClassLoader.defineClass(ClassLoader.java:615) at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:141) at java.net.URLClassLoader.defineClass(URLClassLoader.java:283) at java.net.URLClassLoader.access$000(URLClassLoader.java:58) at java.net.URLClassLoader$1.run(URLClassLoader.java:197) at java.security.AccessController.doPrivileged(Native Method) at java.net.URLClassLoader.findClass(URLClassLoader.java:190) at java.lang.ClassLoader.loadClass(ClassLoader.java:306) at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301) at java.lang.ClassLoader.loadClass(ClassLoader.java:247) at com.rapidminer.gui.look.ui.MenuUI$MenuMouseHandler.mouseEntered(MenuUI.java:62) at java.awt.AWTEventMulticaster.mouseEntered(AWTEventMulticaster.java:283) at java.awt.AWTEventMulticaster.mouseEntered(AWTEventMulticaster.java:282) at java.awt.Component.processMouseEvent(Component.java:6423) at javax.swing.JComponent.processMouseEvent(JComponent.java:3275) at java.awt.Component.processEvent(Component.java:6179) at java.awt.Container.processEvent(Container.java:2083) at java.awt.Component.dispatchEventImpl(Component.java:4776) at java.awt.Container.dispatchEventImpl(Container.java:2141) at java.awt.Component.dispatchEvent(Component.java:4604) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4619) at java.awt.LightweightDispatcher.trackMouseEnterExit(Container.java:4408) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4262) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4210)Exception in thread "AWT-EventQueue-0" java.lang.OutOfMemoryError: PermGen spaceException in thread "AWT-EventQueue-0" java.lang.OutOfMemoryError: PermGen spaceException in thread "AWT-EventQueue-0" java.lang.OutOfMemoryError: PermGen spaceException in thread "AWT-EventQueue-0" java.lang.OutOfMemoryError: PermGen spaceException in thread "AWT-EventQueue-0" java.lang.OutOfMemoryError: PermGen spaceException in thread "AWT-EventQueue-0" java.lang.OutOfMemoryError: PermGen spaceException in thread "AWT-EventQueue-0" java.lang.OutOfMemoryError: PermGen spaceException in thread "AWT-EventQueue-0" java.lang.OutOfMemoryError: PermGen spaceException in thread "AWT-EventQueue-0" java.lang.OutOfMemoryError: PermGen spaceException in thread "AWT-EventQueue-0" java.lang.OutOfMemoryError: PermGen spaceException in thread "AWT-EventQueue-0" java.lang.OutOfMemoryError: PermGen spaceException in thread "AWT-EventQueue-0" java.lang.OutOfMemoryError: PermGen spaceException in thread "AWT-EventQueue-0" java.lang.OutOfMemoryError: PermGen spaceJava HotSpot(TM) 64-Bit Server VM warning: Exception java.lang.OutOfMemoryError occurred dispatching signal Unknown Signal to handler- the VM may need to be forcibly terminatedKilled: 9
