Hello
Does anyone knows the link between the model files .stmod and the directories where the computation and the results are stored ?
Classicaly, I want to run different simulations changing some input data to compare the results and to take some decisions. I want to keep the .stmod with the input parameters.
I prepared one simulation. It runned and the results where obtained. I saved the original file. I saved that file under another name. I change some input paramters. I can run the simulation but the second file still have link with the first simulation. If I delete the first simulation in the "run history" of the second file, the directory of that simulation is deleted.
How to manage this issue ?
Yours sincerely.
