<process version="5.3.005">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.005" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="imageprocessing:multiple_color_image_opener" compatibility="1.4.001" expanded="true" height="60" name="MCIO" width="90" x="45" y="30">
<list key="images">
<parameter key="imageconvert" value="D:\non-photos\research progress\spam image"/>
</list>
<operator activated="true" class="imageprocessing:color_to_grayscale" compatibility="1.4.001" expanded="true" height="60" name="Color to grayscale" width="90" x="45" y="30"/>
<operator activated="true" class="imageprocessing:write_image" compatibility="1.4.001" expanded="true" height="60" name="Write Image to File" width="90" x="179" y="30">
<parameter key="type" value="Use original name"/>
<parameter key="type_of_ext" value=".jpg"/>
<parameter key="directory" value="C:\Documents and Settings\SHAMINI\Desktop\gray image"/>
<connect from_port="color image plus" to_op="Color to grayscale" to_port="color image plus"/>
<connect from_op="Color to grayscale" from_port="grayscale image" to_op="Write Image to File" to_port="image plus"/>
<connect from_op="Write Image to File" from_port="image plus" to_port="Example set"/>
<portSpacing port="source_color image plus" spacing="0"/>
<portSpacing port="sink_Example set" spacing="0"/>
</process>
<connect from_op="MCIO" from_port="example set" to_port="result 1"/>
</process>
</process>
this is my process, in which i want to open multiple color images and convert it into grayscale
and then write it into separate files ..
please help .
