 I'm working with application "steady state AC magnetic coupled with transient thermal 2D" to simulate AC current passing through a coil.
 What are the solver and adjustments that can give accurate and fast results with this type of application?
 I'm using the iterative solver, but it takes too much time to give a result. The direct solver doesn't converge.
 Thank you.
