I need a little help in the GSP operator. I managed to run a GSP problem and obtained the following result from IOObject, however, there is nothing In the "GSPSet (GSP)" window.
0.259:
0.173:
0.173:
0.132:
0.266:
0.140:
It seems to me that the GSP has identified a number of statistical significant patterns and the numbers tell you the confidence level of that sequence. However, I cannot understand what patterns they refer to, for example, I expect a result like:
Seq. pattern: (A, B, C): 0.212
Seq. pattern: (<A,B>, <B,C>): 0.195
Please help. I believe that I may overlook some important steps to visualize the result.
Many thanks,
Bunny
Below is the code I used:
<process version="5.3.008">
<context>
<input>
<location>//Local Repository/data/Sample Data for Sequential Pattern</location>
</input>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="5.3.008" expanded="true" height="60" name="Retrieve Sample Data for Sequential Pattern" width="90" x="45" y="30">
<parameter key="repository_entry" value="//Local Repository/data/Sample Data for Sequential Pattern"/>
<operator activated="true" class="set_role" compatibility="5.3.008" expanded="true" height="76" name="Set Role" width="90" x="112" y="165">
<parameter key="attribute_name" value="consumer id"/>
<operator activated="true" class="numerical_to_binominal" compatibility="5.3.008" expanded="true" height="76" name="Numerical to Binominal" width="90" x="179" y="30">
<parameter key="attributes" value="BLANC DE LA MER|BODY CARE|CLEANSERS & TONICS|EYE CARE|FACIAL SYSTEMS|INFUSIONS|MOISTURIZERS|OTHERS|SERUMS|SETS|SKIN COLOUR|THE CONCENTRATE & THE ESSENCE|"/>
<operator activated="true" class="generalized_sequential_patterns" compatibility="5.3.008" expanded="true" height="76" name="GSP" width="90" x="313" y="165">
<parameter key="customer_id" value="consumer id"/>
<parameter key="time_attribute" value="Calendar Date"/>
<parameter key="min_support" value="0.1"/>
<parameter key="window_size" value="1.0"/>
<parameter key="max_gap" value="500.0"/>
<parameter key="min_gap" value="1.0"/>
<parameter key="positive_value" value="true"/>
<connect from_op="Retrieve Sample Data for Sequential Pattern" from_port="output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Numerical to Binominal" to_port="example set input"/>
<connect from_op="Numerical to Binominal" from_port="example set output" to_op="GSP" to_port="example set"/>
<connect from_op="Numerical to Binominal" from_port="original" to_port="result 1"/>
<connect from_op="GSP" from_port="example set" to_port="result 2"/>
<connect from_op="GSP" from_port="patterns" to_port="result 3"/>
</process>
</process>
