Multiple Kernel Based SVM [SOLVED]
__
__ New Altair Community Member
edited November 5 in Community Q&A
I want to implement Multiple Kernel Based SVM. Is it any how possible to implement it with Rapidminer??
  • MariusHelf
    MariusHelf New Altair Community Member
    Do you want to write Java code to implement that SVM? Then you can create a RapidMiner extension by following the RapidMiner Extension Guide.
    Best regards,
    Marius
  • __
    I have a java code of the same and want to run in rapid miner i.e. the output should be displayed in rapid miner itself. Is this possible by using rapid miner extension??
  • MariusHelf
    Yes, it is - if you want to integrate your code as an operator into RapidMiner, please have a look at the link I posted in my previous post.
  • __
    Thank U so much  :)
