<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data" compatibility="5.3.008" expanded="true" height="60" name="Generate Data" width="90" x="246" y="30"/> <operator activated="true" class="generate_data" compatibility="5.3.008" expanded="true" height="60" name="Generate Data (2)" width="90" x="45" y="165"> <parameter key="number_examples" value="1"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.3.008" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="165"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="label"/> <parameter key="invert_selection" value="true"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="rename_by_generic_names" compatibility="5.3.008" expanded="true" height="76" name="Rename by Generic Names" width="90" x="313" y="165"> <parameter key="generic_name_stem" value="btt"/> </operator> <operator activated="true" class="cartesian_product" compatibility="5.3.008" expanded="true" height="76" name="Cartesian" width="90" x="514" y="30"/> <connect from_op="Generate Data" from_port="output" to_op="Cartesian" to_port="left"/> <connect from_op="Generate Data (2)" from_port="output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Rename by Generic Names" to_port="example set input"/> <connect from_op="Rename by Generic Names" from_port="example set output" to_op="Cartesian" to_port="right"/> <connect from_op="Cartesian" from_port="join" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="imageprocessing:multiple_color_image_opener" compatibility="1.3.003" expanded="true" height="60" name="MCIO(Local Features)" width="90" x="45" y="120"> <list key="images"> <parameter key="test" value="C:\Users\Elena\Dropbox\Master\Thesis\mcio"/> </list> <parameter key="assign_label" value="true"/> <process expanded="true"> <operator activated="true" class="multiply" compatibility="5.3.008" expanded="true" height="94" name="Multiply" width="90" x="45" y="30"/> <operator activated="true" class="imageprocessing:poi_generator" compatibility="1.3.003" expanded="true" height="60" name="Point of interest generator" width="90" x="179" y="165"> <list key="Points Table"/> </operator> <operator activated="true" class="imageprocessing:feature_extraction_operator2" compatibility="1.3.003" expanded="true" height="94" name="Local Feature Extractor with Points" width="90" x="402" y="30"> <parameter key="include_position_in_img" value="false"/> <parameter key="window_width" value="15"/> <parameter key="window_height" value="15"/> <process expanded="true"> <operator activated="true" class="imageprocessing:color_to_grayscale" compatibility="1.3.003" expanded="true" height="60" name="Color to grayscale" width="90" x="45" y="30"/> <operator activated="true" class="imageprocessing:line_haar_like_feature" compatibility="1.3.003" expanded="true" height="60" name="Line Haar-like feature" width="90" x="402" y="30"/> <connect from_port="image 1" to_op="Color to grayscale" to_port="color image plus"/> <connect from_op="Color to grayscale" from_port="grayscale image" to_op="Line Haar-like feature" to_port="grayscale image plus"/> <connect from_op="Line Haar-like feature" from_port="feature" to_port="feature 1"/> <portSpacing port="source_image 1" spacing="0"/> <portSpacing port="source_image 2" spacing="0"/> <portSpacing port="sink_feature 1" spacing="0"/> <portSpacing port="sink_feature 2" spacing="0"/> </process> </operator> <connect from_port="color image plus" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Local Feature Extractor with Points" to_port="color image plus"/> <connect from_op="Multiply" from_port="output 2" to_op="Point of interest generator" to_port="img"/> <connect from_op="Point of interest generator" from_port="points of interest" to_op="Local Feature Extractor with Points" to_port="points"/> <connect from_op="Local Feature Extractor with Points" from_port="example set" to_port="Example set"/> <portSpacing port="source_color image plus" spacing="0"/> <portSpacing port="sink_Example set" spacing="0"/> </process> </operator> <operator activated="true" class="imageprocessing:multiple_color_image_opener" compatibility="1.3.003" expanded="true" height="60" name="MCIO(Global Features)" width="90" x="45" y="30"> <list key="images"> <parameter key="city" value="C:\Users\Elena\Dropbox\Master\Thesis\mcio"/> </list> <parameter key="auto_adjust_contrast" value="true"/> <process expanded="true"> <operator activated="true" class="imageprocessing:global_feature_extraction" compatibility="1.3.003" expanded="true" height="60" name="Global Feature Extractor from a Single Image" width="90" x="334" y="30"> <process expanded="true"> <operator activated="true" class="imageprocessing:color_model_operator" compatibility="1.3.003" expanded="true" name="ClrToGS(Hue)"> <parameter key="Color component" value="Hue"/> </operator> <operator activated="true" class="imageprocessing:color_model_operator" compatibility="1.3.003" expanded="true" name="ClrToGS (Saturation)"> <parameter key="Color component" value="Saturation"/> </operator> <operator activated="true" class="imageprocessing:color_model_operator" compatibility="1.3.003" expanded="true" name="ClrToGS (Value)"> <parameter key="Color component" value="Value"/> </operator> <operator activated="true" class="imageprocessing:statistics" compatibility="1.3.003" expanded="true" name="Global statistics"/> <operator activated="true" class="imageprocessing:create_color_image" compatibility="1.3.003" expanded="true" name="Create Color Image"/> <operator activated="true" class="imageprocessing:histogram" compatibility="1.3.003" expanded="true" name="histogram(H)"/> <connect from_port="color image plus 1" to_op="ClrToGS(Hue)" to_port="color image plus"/> <connect from_port="color image plus 2" to_op="ClrToGS (Saturation)" to_port="color image plus"/> <connect from_port="color image plus 3" to_op="ClrToGS (Value)" to_port="color image plus"/> <connect from_port="color image plus 4" to_op="Global statistics" to_port="color image plus"/> <connect from_op="ClrToGS(Hue)" from_port="grayscale image plus" to_op="Create Color Image" to_port="grayscale image plus X"/> <connect from_op="ClrToGS (Saturation)" from_port="grayscale image plus" to_op="Create Color Image" to_port="grayscale image plus Y"/> <connect from_op="ClrToGS (Value)" from_port="grayscale image plus" to_op="Create Color Image" to_port="grayscale image plus Z"/> <connect from_op="Global statistics" from_port="features" to_port="feature 2"/> <connect from_op="Create Color Image" from_port="color image plus" to_op="histogram(H)" to_port="color image plus"/> <connect from_op="histogram(H)" from_port="features" to_port="feature 1"/> <portSpacing port="source_color image plus 1" spacing="0"/> <portSpacing port="source_color image plus 2" spacing="0"/> <portSpacing port="source_color image plus 3" spacing="0"/> <portSpacing port="source_color image plus 4" spacing="0"/> <portSpacing port="source_color image plus 5" spacing="0"/> <portSpacing port="sink_feature 1" spacing="0"/> <portSpacing port="sink_feature 2" spacing="0"/> <portSpacing port="sink_feature 3" spacing="0"/> </process> </operator> <connect from_port="color image plus" to_op="Global Feature Extractor from a Single Image" to_port="color image plus"/> <connect from_op="Global Feature Extractor from a Single Image" from_port="example set" to_port="Example set"/> <portSpacing port="source_color image plus" spacing="0"/> <portSpacing port="sink_Example set" spacing="0"/> </process> </operator> <operator activated="true" class="join" compatibility="5.3.008" expanded="true" height="76" name="Join" width="90" x="246" y="75"> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="FileName" value="FileName"/> </list> </operator> <connect from_op="MCIO(Local Features)" from_port="example set" to_op="Join" to_port="right"/> <connect from_op="MCIO(Global Features)" from_port="example set" to_op="Join" to_port="left"/> <connect from_op="Join" from_port="join" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="imagemining:read_images" compatibility="5.0.000" expanded="true" height="60" name="read_images" width="90" x="45" y="210"> <parameter key="directory" value="C:\Users\Elena\Dropbox\Master\Thesis\mcio"/> <parameter key="label" value="test"/> </operator> <operator activated="true" class="imagemining:scalable_color" compatibility="5.0.000" expanded="true" height="76" name="Scalable Color" width="90" x="179" y="210"/> <operator activated="true" class="transpose" compatibility="5.3.008" expanded="true" height="76" name="Transpose" width="90" x="313" y="210"/> <operator activated="true" class="retrieve" compatibility="5.3.008" expanded="true" height="60" name="Retrieve testRepo" width="90" x="45" y="480"> <parameter key="repository_entry" value="testRepo"/> </operator> <operator activated="true" class="rename_by_replacing" compatibility="5.3.008" expanded="true" height="76" name="Rename by Replacing" width="90" x="45" y="345"> <parameter key="attribute_filter_type" value="regular_expression"/> <parameter key="regular_expression" value="^(?:[a-zA-Z]\:(\\|\/)|file\:\/\/|\\\\|\.(\/|\\))([^\\\/\:\*\?\<\>\"\|]+(\\|\/){0,1})+$"/> <parameter key="replace_what" value="^(?:[a-zA-Z]\:(\\|\/)|file\:\/\/|\\\\|\.(\/|\\))([^\\\/\:\*\?\<\>\"\|]+(\\|\/){0,1})+$"/> <parameter key="replace_by" value="$3.jpg"/> </operator> <operator activated="true" class="transpose" compatibility="5.3.008" expanded="true" height="76" name="Transpose (2)" width="90" x="179" y="345"/> <operator activated="true" class="imageprocessing:multiple_color_image_opener" compatibility="1.3.003" expanded="true" height="60" name="MCIO(Local Features)" width="90" x="45" y="120"> <list key="images"> <parameter key="city" value="C:\Users\Elena\Dropbox\Master\Thesis\mcio"/> </list> <parameter key="assign_label" value="true"/> <process expanded="true"> <operator activated="true" class="multiply" compatibility="5.3.008" expanded="true" name="Multiply"/> <operator activated="true" class="imageprocessing:poi_generator" compatibility="1.3.003" expanded="true" name="Point of interest generator"> <list key="Points Table"/> </operator> <operator activated="true" class="imageprocessing:feature_extraction_operator2" compatibility="1.3.003" expanded="true" name="Local Feature Extractor with Points"> <parameter key="include_position_in_img" value="false"/> <parameter key="window_width" value="15"/> <parameter key="window_height" value="15"/> <process expanded="true"> <operator activated="true" class="imageprocessing:color_to_grayscale" compatibility="1.3.003" expanded="true" name="Color to grayscale"/> <operator activated="true" class="imageprocessing:line_haar_like_feature" compatibility="1.3.003" expanded="true" name="Line Haar-like feature"/> <connect from_port="image 1" to_op="Color to grayscale" to_port="color image plus"/> <connect from_op="Color to grayscale" from_port="grayscale image" to_op="Line Haar-like feature" to_port="grayscale image plus"/> <connect from_op="Line Haar-like feature" from_port="feature" to_port="feature 1"/> <portSpacing port="source_image 1" spacing="0"/> <portSpacing port="source_image 2" spacing="0"/> <portSpacing port="sink_feature 1" spacing="0"/> <portSpacing port="sink_feature 2" spacing="0"/> </process> </operator> <connect from_port="color image plus" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Local Feature Extractor with Points" to_port="color image plus"/> <connect from_op="Multiply" from_port="output 2" to_op="Point of interest generator" to_port="img"/> <connect from_op="Point of interest generator" from_port="points of interest" to_op="Local Feature Extractor with Points" to_port="points"/> <connect from_op="Local Feature Extractor with Points" from_port="example set" to_port="Example set"/> <portSpacing port="source_color image plus" spacing="0"/> <portSpacing port="sink_Example set" spacing="0"/> </process> </operator> <operator activated="true" class="imageprocessing:multiple_color_image_opener" compatibility="1.3.003" expanded="true" height="60" name="MCIO(Global Features)" width="90" x="45" y="30"> <list key="images"> <parameter key="city" value="C:\Users\Elena\Dropbox\Master\Thesis\mcio"/> </list> <parameter key="auto_adjust_contrast" value="true"/> <process expanded="true"> <operator activated="true" class="imageprocessing:global_feature_extraction" compatibility="1.3.003" expanded="true" name="Global Feature Extractor from a Single Image"> <process expanded="true"> <operator activated="true" class="imageprocessing:color_model_operator" compatibility="1.3.003" expanded="true" name="ClrToGS(Hue)"> <parameter key="Color component" value="Hue"/> </operator> <operator activated="true" class="imageprocessing:color_model_operator" compatibility="1.3.003" expanded="true" name="ClrToGS (Saturation)"> <parameter key="Color component" value="Saturation"/> </operator> <operator activated="true" class="imageprocessing:color_model_operator" compatibility="1.3.003" expanded="true" name="ClrToGS (Value)"> <parameter key="Color component" value="Value"/> </operator> <operator activated="true" class="imageprocessing:statistics" compatibility="1.3.003" expanded="true" name="Global statistics"/> <operator activated="true" class="imageprocessing:create_color_image" compatibility="1.3.003" expanded="true" name="Create Color Image"/> <operator activated="true" class="imageprocessing:histogram" compatibility="1.3.003" expanded="true" name="histogram(H)"/> <connect from_port="color image plus 1" to_op="ClrToGS(Hue)" to_port="color image plus"/> <connect from_port="color image plus 2" to_op="ClrToGS (Saturation)" to_port="color image plus"/> <connect from_port="color image plus 3" to_op="ClrToGS (Value)" to_port="color image plus"/> <connect from_port="color image plus 4" to_op="Global statistics" to_port="color image plus"/> <connect from_op="ClrToGS(Hue)" from_port="grayscale image plus" to_op="Create Color Image" to_port="grayscale image plus X"/> <connect from_op="ClrToGS (Saturation)" from_port="grayscale image plus" to_op="Create Color Image" to_port="grayscale image plus Y"/> <connect from_op="ClrToGS (Value)" from_port="grayscale image plus" to_op="Create Color Image" to_port="grayscale image plus Z"/> <connect from_op="Global statistics" from_port="features" to_port="feature 2"/> <connect from_op="Create Color Image" from_port="color image plus" to_op="histogram(H)" to_port="color image plus"/> <connect from_op="histogram(H)" from_port="features" to_port="feature 1"/> <portSpacing port="source_color image plus 1" spacing="0"/> <portSpacing port="source_color image plus 2" spacing="0"/> <portSpacing port="source_color image plus 3" spacing="0"/> <portSpacing port="source_color image plus 4" spacing="0"/> <portSpacing port="source_color image plus 5" spacing="0"/> <portSpacing port="sink_feature 1" spacing="0"/> <portSpacing port="sink_feature 2" spacing="0"/> <portSpacing port="sink_feature 3" spacing="0"/> </process> </operator> <connect from_port="color image plus" to_op="Global Feature Extractor from a Single Image" to_port="color image plus"/> <connect from_op="Global Feature Extractor from a Single Image" from_port="example set" to_port="Example set"/> <portSpacing port="source_color image plus" spacing="0"/> <portSpacing port="sink_Example set" spacing="0"/> </process> </operator> <operator activated="true" class="join" compatibility="5.3.008" expanded="true" height="76" name="Join" width="90" x="179" y="75"> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="FileName" value="FileName"/> </list> </operator> <operator activated="true" class="join" compatibility="5.3.008" expanded="true" height="76" name="Join (2)" width="90" x="447" y="165"> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="FileName" value="id"/> </list> </operator> <operator activated="true" class="join" compatibility="5.3.008" expanded="true" height="76" name="Join (3)" width="90" x="581" y="255"> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="FileName" value="file"/> </list> </operator> <connect from_op="read_images" from_port="images" to_op="Scalable Color" to_port="input"/> <connect from_op="Scalable Color" from_port="output" to_op="Transpose" to_port="example set input"/> <connect from_op="Transpose" from_port="example set output" to_op="Rename by Replacing" to_port="example set input"/> <connect from_op="Retrieve testRepo" from_port="output" to_op="Join (3)" to_port="right"/> <connect from_op="Rename by Replacing" from_port="example set output" to_op="Transpose (2)" to_port="example set input"/> <connect from_op="Transpose (2)" from_port="example set output" to_op="Join (2)" to_port="right"/> <connect from_op="MCIO(Local Features)" from_port="example set" to_op="Join" to_port="right"/> <connect from_op="MCIO(Global Features)" from_port="example set" to_op="Join" to_port="left"/> <connect from_op="Join" from_port="join" to_op="Join (2)" to_port="left"/> <connect from_op="Join (2)" from_port="join" to_op="Join (3)" to_port="left"/> <connect from_op="Join (3)" from_port="join" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
