<?xml version="1.0" encoding="UTF-8" standalone="no"?> <process version="5.3.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data" compatibility="5.3.008" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"/> <operator activated="true" class="series:differentiate_example_set" compatibility="5.3.000" expanded="true" height="76" name="Differentiate" width="90" x="179" y="30"> <parameter key="attribute_name" value="label"/> <parameter key="change_mode" value="direction"/> <parameter key="keep_original_attribute" value="false"/> </operator> <operator activated="true" class="filter_examples" compatibility="5.3.008" expanded="true" height="76" name="Filter Examples" width="90" x="313" y="30"> <parameter key="condition_class" value="no_missing_attributes"/> </operator> <operator activated="true" class="set_role" compatibility="5.3.008" expanded="true" height="76" name="Set Role" width="90" x="447" y="30"> <parameter key="attribute_name" value="change(label)"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="nominal_to_binominal" compatibility="5.3.008" expanded="true" height="94" name="Nominal to Binominal" width="90" x="581" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="change(label)"/> <parameter key="include_special_attributes" value="true"/> <parameter key="transform_binominal" value="true"/> </operator> <operator activated="true" class="series:sliding_window_validation" compatibility="5.3.000" expanded="true" height="112" name="Validation" width="90" x="715" y="30"> <parameter key="training_window_width" value="60"/> <parameter key="training_window_step_size" value="1"/> <parameter key="test_window_width" value="1"/> <process expanded="true"> <operator activated="true" class="support_vector_machine_linear" compatibility="5.3.008" expanded="true" height="76" name="SVM (Linear)" width="90" x="45" y="30"/> <connect from_port="training" to_op="SVM (Linear)" to_port="training set"/> <connect from_op="SVM (Linear)" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="5.3.008" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="series:forecasting_performance" compatibility="5.3.000" expanded="true" height="76" name="Performance" width="90" x="179" y="30"> <parameter key="horizon" value="1"/> </operator> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_op="Generate Data" from_port="output" to_op="Differentiate" to_port="example set input"/> <connect from_op="Differentiate" from_port="example set output" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Nominal to Binominal" to_port="example set input"/> <connect from_op="Nominal to Binominal" from_port="example set output" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="model" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?> <process version="5.3.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="subprocess" compatibility="5.3.008" expanded="true" height="76" name="Sub Generate Data" width="90" x="45" y="30"> <process expanded="true"> <operator activated="true" class="generate_data" compatibility="5.3.008" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"/> <operator activated="true" class="series:differentiate_example_set" compatibility="5.3.000" expanded="true" height="76" name="Differentiate" width="90" x="179" y="30"> <parameter key="attribute_name" value="label"/> <parameter key="change_mode" value="direction"/> <parameter key="keep_original_attribute" value="false"/> </operator> <operator activated="true" class="filter_examples" compatibility="5.3.008" expanded="true" height="76" name="Filter Examples" width="90" x="315" y="30"> <parameter key="condition_class" value="no_missing_attributes"/> </operator> <operator activated="true" class="set_role" compatibility="5.3.008" expanded="true" height="76" name="Set Role" width="90" x="447" y="30"> <parameter key="attribute_name" value="change(label)"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="rename" compatibility="5.3.008" expanded="true" height="76" name="Rename" width="90" x="581" y="30"> <parameter key="old_name" value="change(label)"/> <parameter key="new_name" value="label"/> <list key="rename_additional_attributes"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Differentiate" to_port="example set input"/> <connect from_op="Differentiate" from_port="example set output" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="multiply" compatibility="5.3.008" expanded="true" height="94" name="Multiply" width="90" x="179" y="120"/> <operator activated="true" class="series:sliding_window_validation" compatibility="5.3.000" expanded="true" height="112" name="Validation" width="90" x="313" y="30"> <parameter key="training_window_width" value="60"/> <parameter key="training_window_step_size" value="1"/> <parameter key="test_window_width" value="1"/> <process expanded="true"> <operator activated="true" class="support_vector_machine_linear" compatibility="5.3.008" expanded="true" height="76" name="SVM (Linear)" width="90" x="45" y="30"/> <connect from_port="training" to_op="SVM (Linear)" to_port="training set"/> <connect from_op="SVM (Linear)" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="5.3.008" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.3.008" expanded="true" height="76" name="Performance (2)" width="90" x="179" y="30"/> <operator activated="false" class="series:forecasting_performance" compatibility="5.3.000" expanded="true" height="76" name="Performance" width="90" x="179" y="165"> <parameter key="horizon" value="1"/> </operator> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Performance (2)" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="apply_model" compatibility="5.3.008" expanded="true" height="76" name="Apply Model (2)" width="90" x="447" y="165"> <list key="application_parameters"/> </operator> <connect from_op="Sub Generate Data" from_port="out 1" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Validation" to_port="training"/> <connect from_op="Multiply" from_port="output 2" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Validation" from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_op="Validation" from_port="averagable 1" to_port="result 1"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="36"/> <portSpacing port="sink_result 2" spacing="90"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator> </process>
