<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="parallel:x_validation_parallel" compatibility="5.3.000" expanded="true" height="112" name="Validation" width="90" x="112" y="30"> <process expanded="true"> <operator activated="true" class="optimize_selection_forward" compatibility="5.3.008" expanded="true" height="94" name="Forward Selection (2)" width="90" x="45" y="30"> <parameter key="maximal_number_of_attributes" value="700"/> <parameter key="speculative_rounds" value="5"/> <parameter key="parallelize_learning_process" value="true"/> <process expanded="true"> <operator activated="true" class="x_validation" compatibility="5.3.008" expanded="true" name="FSValidation (3)"> <parameter key="leave_one_out" value="true"/> <process expanded="true"> <operator activated="true" class="support_vector_machine_linear" compatibility="5.3.008" expanded="true" name="SVM (5)"> <parameter key="balance_cost" value="true"/> </operator> <connect from_port="training" to_op="SVM (5)" to_port="training set"/> <connect from_op="SVM (5)" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> <portSpacing port="sink_through 2" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="5.3.008" expanded="true" name="Apply Model (5)"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_classification" compatibility="5.3.008" expanded="true" name="Performance (7)"> <parameter key="main_criterion" value="accuracy"/> <parameter key="classification_error" value="true"/> <parameter key="kappa" value="true"/> <parameter key="correlation" value="true"/> <list key="class_weights"/> </operator> <operator activated="true" class="performance_min_max" compatibility="5.3.008" expanded="true" name="Performance (8)"> <parameter key="minimum_weight" value="0.5"/> </operator> <connect from_port="model" to_op="Apply Model (5)" to_port="model"/> <connect from_port="test set" to_op="Apply Model (5)" to_port="unlabelled data"/> <connect from_port="through 1" to_port="averagable 2"/> <connect from_op="Apply Model (5)" from_port="labelled data" to_op="Performance (7)" to_port="labelled data"/> <connect from_op="Performance (7)" from_port="performance" to_op="Performance (8)" to_port="performance vector"/> <connect from_op="Performance (8)" from_port="performance vector" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="source_through 2" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> <portSpacing port="sink_averagable 3" spacing="0"/> </process> </operator> <connect from_port="example set" to_op="FSValidation (3)" to_port="training"/> <connect from_op="FSValidation (3)" from_port="averagable 1" to_port="performance"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> </process> </operator> <operator activated="true" class="support_vector_machine_linear" compatibility="5.3.008" expanded="true" height="76" name="SVM (6)" width="90" x="313" y="30"> <parameter key="balance_cost" value="true"/> </operator> <connect from_port="training" to_op="Forward Selection (2)" to_port="example set"/> <connect from_op="Forward Selection (2)" from_port="example set" to_op="SVM (6)" to_port="training set"/> <connect from_op="Forward Selection (2)" from_port="attribute weights" to_port="through 1"/> <connect from_op="SVM (6)" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="90"/> <portSpacing port="sink_through 2" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="select_by_weights" compatibility="5.3.008" expanded="true" height="94" name="Select by Weights (2)" width="90" x="45" y="120"/> <operator activated="true" class="apply_model" compatibility="5.3.008" expanded="true" height="76" name="Apply Model (6)" width="90" x="179" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.3.008" expanded="true" height="76" name="Performance (9)" width="90" x="313" y="30"/> <connect from_port="model" to_op="Apply Model (6)" to_port="model"/> <connect from_port="test set" to_op="Select by Weights (2)" to_port="example set input"/> <connect from_port="through 1" to_op="Select by Weights (2)" to_port="weights"/> <connect from_op="Select by Weights (2)" from_port="example set output" to_op="Apply Model (6)" to_port="unlabelled data"/> <connect from_op="Apply Model (6)" from_port="labelled data" to_op="Performance (9)" to_port="labelled data"/> <connect from_op="Performance (9)" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="72"/> <portSpacing port="source_through 2" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
