<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="series:generate_series_sinus" compatibility="5.3.000" expanded="true" height="60" name="Generate Series (Sinus)" width="90" x="45" y="30"> <list key="frequency"> <parameter key="5.0" value="3.0"/> <parameter key="50.0" value="0.5"/> </list> </operator> <connect from_op="Generate Series (Sinus)" from_port="output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
