[SOLVED] Image Mining: Color Histogram
User: "Legacy User"
New Altair Community Member
Updated by Jocelyn
I would like to ask what is the best strategy for extracting color histograms and specifically HSV.
In the following workflow I am trying to extract Hue, Saturation and Value like tis:
- Multiple Color Image Opener
 -Global Feature Extraction from Single Image
   -Color to Grayscale->Grayscale to Color->Histogram (performed 3 times, one for H, one for S and one for V)
I get the exception: Duplicate attribute name Histogram0.
Is this the correct way to extract histograms, or is there something wrong with the workflow?
<process version="5.3.008">
 <context>
   <input/>
   <output/>
   <macros/>
 </context>
 <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process">
   <parameter key="logfile" value="C:\Users\Elena\Dropbox\Master\Thesis\RapidMiner\logfile\log.txt"/>
   <parameter key="resultfile" value="C:\Users\Elena\Dropbox\Master\Thesis\RapidMiner\resultfile\resultfile.txt"/>
   <process expanded="true">
     <operator activated="true" class="imageprocessing:multiple_color_image_opener" compatibility="1.4.001" expanded="true" height="60" name="MCIO(H)" width="90" x="45" y="30">
       <list key="images">
         <parameter key="city" value="C:\Users\Elena\Dropbox\Master\Thesis\mcio"/>
       </list>
       <parameter key="auto_adjust_contrast" value="true"/>
         <operator activated="true" class="imageprocessing:global_feature_extraction" compatibility="1.4.001" expanded="true" height="60" name="Global Feature Extractor from a Single Image" width="90" x="246" y="75">
           <parameter key="include_position_filename" value="false"/>
             <operator activated="true" class="imageprocessing:color_model_operator" compatibility="1.4.001" expanded="true" height="60" name="ClrToGS(Hue)" width="90" x="45" y="30">
               <parameter key="Color component" value="Hue"/>
             <operator activated="true" class="imageprocessing:grayscale_to_color" compatibility="1.4.001" expanded="true" height="60" name="Grayscale to color" width="90" x="246" y="75"/>
             <operator activated="true" class="imageprocessing:color_model_operator" compatibility="1.4.001" expanded="true" height="60" name="ClrToGS (Saturation)" width="90" x="45" y="120">
               <parameter key="Color component" value="Saturation"/>
             <operator activated="true" class="imageprocessing:color_model_operator" compatibility="1.4.001" expanded="true" height="60" name="ClrToGS (Value)" width="90" x="45" y="210">
               <parameter key="Color component" value="Value"/>
             <operator activated="true" class="imageprocessing:grayscale_to_color" compatibility="1.4.001" expanded="true" height="60" name="Grayscale to color (2)" width="90" x="246" y="255"/>
             <operator activated="true" class="imageprocessing:grayscale_to_color" compatibility="1.4.001" expanded="true" height="60" name="Grayscale to color (3)" width="90" x="246" y="165"/>
             <operator activated="true" class="imageprocessing:histogram" compatibility="1.4.001" expanded="true" height="60" name="histogram(H)" width="90" x="447" y="75"/>
             <operator activated="true" class="imageprocessing:histogram" compatibility="1.4.001" expanded="true" height="60" name="histogram (S)" width="90" x="447" y="165"/>
             <operator activated="true" class="imageprocessing:histogram" compatibility="1.4.001" expanded="true" height="60" name="histogram (V)" width="90" x="447" y="255"/>
             <connect from_port="color image plus 1" to_op="ClrToGS(Hue)" to_port="color image plus"/>
             <connect from_port="color image plus 2" to_op="ClrToGS (Saturation)" to_port="color image plus"/>
             <connect from_port="color image plus 3" to_op="ClrToGS (Value)" to_port="color image plus"/>
             <connect from_op="ClrToGS(Hue)" from_port="grayscale image plus" to_op="Grayscale to color" to_port="grayscale image plus"/>
             <connect from_op="Grayscale to color" from_port="color image" to_op="histogram(H)" to_port="color image plus"/>
             <connect from_op="ClrToGS (Saturation)" from_port="grayscale image plus" to_op="Grayscale to color (3)" to_port="grayscale image plus"/>
             <connect from_op="ClrToGS (Value)" from_port="grayscale image plus" to_op="Grayscale to color (2)" to_port="grayscale image plus"/>
             <connect from_op="Grayscale to color (2)" from_port="color image" to_op="histogram (V)" to_port="color image plus"/>
             <connect from_op="Grayscale to color (3)" from_port="color image" to_op="histogram (S)" to_port="color image plus"/>
             <connect from_op="histogram(H)" from_port="features" to_port="feature 1"/>
             <connect from_op="histogram (S)" from_port="features" to_port="feature 2"/>
             <connect from_op="histogram (V)" from_port="features" to_port="feature 3"/>
             <portSpacing port="source_color image plus 1" spacing="0"/>
             <portSpacing port="source_color image plus 2" spacing="0"/>
             <portSpacing port="source_color image plus 3" spacing="0"/>
             <portSpacing port="source_color image plus 4" spacing="0"/>
             <portSpacing port="sink_feature 1" spacing="0"/>
             <portSpacing port="sink_feature 2" spacing="0"/>
             <portSpacing port="sink_feature 3" spacing="0"/>
             <portSpacing port="sink_feature 4" spacing="0"/>
           </process>
         <connect from_port="color image plus" to_op="Global Feature Extractor from a Single Image" to_port="color image plus"/>
         <connect from_op="Global Feature Extractor from a Single Image" from_port="example set" to_port="Example set"/>
         <portSpacing port="source_color image plus" spacing="0"/>
         <portSpacing port="sink_Example set" spacing="0"/>
       </process>
     <connect from_op="MCIO(H)" from_port="example set" to_port="result 1"/>
   </process>
</process>
1 - 9 of 91
    User: "StaryVena"
    Hello elag,
    you can combine HSV channels to one image and then create histogram:
    <process version="5.3.005">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="5.3.005" expanded="true" name="Process">
            <list key="images">
            </list>
                  <operator activated="true" class="imageprocessing:create_color_image" compatibility="1.4.001" expanded="true" height="94" name="Create Color Image" width="90" x="246" y="75"/>
                  <connect from_op="ClrToGS(Hue)" from_port="grayscale image plus" to_op="Create Color Image" to_port="grayscale image plus X"/>
                  <connect from_op="ClrToGS (Saturation)" from_port="grayscale image plus" to_op="Create Color Image" to_port="grayscale image plus Y"/>
                  <connect from_op="ClrToGS (Value)" from_port="grayscale image plus" to_op="Create Color Image" to_port="grayscale image plus Z"/>
                  <connect from_op="Create Color Image" from_port="color image plus" to_op="histogram(H)" to_port="color image plus"/>
                </process>
            </process>
        </process>
    </process>
    Best,
    Vaclav
    User: "Legacy User"
    OP
    Hello StaryVena,
    thank you for the reply and I am sorry for my delay to reply. It is just that I am trying to understand what information do I get. With your workflow but also when I try to extract H,S or V separately the result that I get is 0.001 at histogram62 and 0.999 at histogram63(0..000  and 1.000 when I do only H,S or V).
    -Does then number of bins even plays a role here?
    -Why is the result displayed at  histogram62 and  histogram63 and not in another one?
    -And finally what does this information tells me about the particular image? If e.g. I extract histograms only for Value and I get 1.000 at histogram63, does this mean that my image is very bright? But for which Hue?
    I know that these are understanding questions, but although I understand HSV model I don't understand the information that RapidMiner give me here.
    I hope this was not too much.
    Best,
    elag
    User: "StaryVena"
    Hello elag,
    I don't know image do you have, so it is hard to say.
    Maybe you have image with only two colors or only similar colors in small range. Try to set histogram bins to 128.
    Image is converted to gray scale before histogram is calculated. So in color image it is hard to say. But if you have only hue channel it is the max value of hue.
    If you explain what you want to do, maybe I can help you more.
    Best,
    Vaclav
    User: "Legacy User"
    OP
    Hello Vaclav,
    thanks for the reply.
    What I want to do is extract HSV color histograms. My test photo has more than 2 colors and even when I try to extract only one of the HSV channel Iend up having values only on histogram 62, 63. This is either wrong or I don't understand what should the HSV result be.
    Best,
    Elena
    User: "StaryVena"
    Hello Elena,
    can you post example image? I will try it.
    Best,
    Vaclav
    User: "Legacy User"
    OP
    Hi  Vaclav,
    i sent you a pm with the image.
    Thank you very much,
    Elena
    User: "Legacy User"
    OP
    Problem Solved.
    The workflow provided above from Vaclav was correct. There was a bug in my  version of the image extension.
    User: "nsand102"
    Could you please share your model because i am unable to run the process model, as i am getting errors.
    User: "sgenzer"
    hello @nsand102 - this is a 5-year-old thread. I have a hunch that no one is going to respond. I would start a new thread AND include your process XML AND some sample data.
    Thanks!
    Scott
