"not able to run gui in mac[SOLVED]"
studhadoop
I am able to install rapidminer in windows.
But i am not able to install in mac.
scripts/rapidminer works fine.but scripts/rapidminerGUI not starting
saying not able to create directory under /users/stud/.RapidMiner5
MacOS
Marco_Boeck
do you have write access permissions for your user home "/Users/stud" folder?
Marco
studhadoop
I am not able to do anything in my /Users/stud
I tried to create a .RapidMiner5 directory in /Users/stud but permission denied ???
Marco_Boeck
you really should be allowed to write into your own user home folder. RapidMiner needs to setup the .RapidMiner5 folder to store various things. You can have a look at
this
thread where someone with a Mac has a similiar problem.
Marco
studhadoop
i tried the commands in that post but still
mkdir: /Users/stud/.RapidMiner5: Operation not permitted
Marco_Boeck
well that's a Mac problem then, not a RapidMiner problem
You need to be able to write into your own user home folder, then you can launch RapidMiner.
Marco
MacPhotoBiker
Hi studhadoop,
you don't really need to "install" rapidminer on you Mac, I'd suggest you try the following:
1) Download the version for "other systems" from here:
http://rapid-i.com/content/view/169/82/
2) Unzip and put the folder "rapidminer" in a folder where you do have write access, probably your desktop should be a good place to start with.
3) go to the subfolder "lib", then double click on "rapidminer.jar"
Rapidminer should now open. You may also want to create a shortcut to rapidminer.jar, and put it directly onto your desktop.
I hope that helps.
studhadoop
hi MacPhotoBiker
Actually i am trying in my desktop folder.
At first i tried with lib->rapidminer.jar but it hangs out in"Loading GUI"
it doesnt worked then i tried java -jar lib/rapidminer.jar That also didn't worked fine
then i did scripts/rapidminer this actually worked then i tried to start GUI using scripts/RapidMinerGUI. It results in error saying /User/stud/.RapidMiner5 is not created.
so i tried to create a folder in /Users/stud
MacPhotoBiker
Sorry to hear about your problems. It's not that I'm that much of a "pro", but I got it running on both a Mac and a Linux machine, and since so far you didn't get any better advice, I'd like to try to help you and share my experiences with you.
"Operation not permitted" sounds very much like improper read/write access.
In Finder, right click on the rapidminer folder, and choose "Get info". Then a new window opens, at the very bottom it shows "Sharing & Permissions". In column "Name" your username should appear, and your privilege should be "Read & Write".
On my end, I did not need to create any folders manually. I can open the entire application just by double clicking /lib/rapidminer.jar I'm pointing this out because I believe that the error message "folder not created" won't be solved by just creating the folders manually, they rather indicate that "something else" goes wrong.
Please let me know your read/write access on the rapidminer folder. Good luck!
MacPhotoBiker
On more thing: Besides the read/ write access you also may need to set the proper ownership of the rapidminer folder. Try this:
In a Terminal window, go to the directory that contains the rapidminer folder, i. e when you type ls, you should see the rapidminer folder (among other folders and files).
To modify ownership: chown -R YourUserName:YourUserName rapidminer
To set write access" chmod -R 755 rapidminer
Let us know if this works. Also, you should verify that java is properly installed.
Good luck.
studhadoop
hi MacPhotoBiker,
I gone through ur post and did what ever u advised
rapidminer folder
total 0
drwxr-xr-x 18 stud staff 612 May 7 11:19 rapidminer
In "Sharing & Permissions". In column "Name" it is stud, and privilege is "Read & Write".
And i did chmod -R 755 rapidminer
[tt]
Stud-2:rapidminer stud$ scripts/rapidminer
No maximum Java memory defined, using 1024 Mb...
Java version: 16
grep: /proc/cpuinfo: No such file or directory
Number of cores: 4
Number of GC Threads: 3
Starting RapidMiner from '/Users/stud/desktop/hadoop/Rapid-I/rapidminer', using classes from '/Users/stud/desktop/hadoop/Rapid-I/rapidminer/lib/rapidminer.jar'...
Java version: 16
Starting with CMS garbage collector
Starting in multi-core mode
RapidMiner version 5.3.008, Copyright (C) 2001-2012
RapidMiner comes with ABSOLUTELY NO WARRANTY; This is free software,
and you are welcome to redistribute it under certain conditions;
see license information in the file named LICENSE.
Usage: com.rapidminer.RapidMinerCommandLine [-f] PROCESS [-Mname=value]
PROCESS a repository location containing a process
-f interpret PROCESS as a file rather than a repository location (deprecated)
-Mname=value sets the macro 'name' with the value 'value
Stud-2:rapidminer stud$ scripts/rapidminerGUI
Number of cores: 4
Java version: 16
May 18, 2013 9:44:11 AM com.rapid_i.Launcher ensureRapidMinerHomeSet
INFO: rapidminer.home is '/Users/stud/desktop/hadoop/Rapid-I/rapidminer'.
May 18, 2013 9:44:11 AM com.rapid_i.Launcher main
INFO: Launching RapidMiner, platform ANY
May 18, 2013 9:44:11 AM com.rapidminer.tools.FileSystemService getUserRapidMinerDir
WARNING: Unable to create user home rapidminer directory /Users/stud/.RapidMiner5
May 18, 2013 9:44:11 AM com.rapidminer.tools.ParameterService init
INFO: Reading configuration resource com/rapidminer/resources/rapidminerrc.
[/tt]
studhadoop
Thanks it works
I did it in root
