Split data
User: "oli"
New Altair Community Member
Updated by Jocelyn
I have got another question, hopefully someone might be able to point me in the right direction.
I am using the knn process and looping through a lot of data based on the name.
I want to split my data but by different amounts depending on where I am through the data.
My decisions are done on a time basis, the top part of my data is the earliest observations and the bottom the later observations. I will try and show an simple example below.
Example Name 1 is in the data set 10 times. The first time it appears in the data set it will have no previous results so a KNN can not be done, so I would discard this example.
The second time the name appears I want to base the KNN on the example that has happened before, so the top 10% of the data for Name 1 would go into creating the model. Then the current example would go into apply model and I would discard the other 80% (as from this examples point of view it has not happened yet so it is information I would not have at the time).
The third time the name appears I would base the KNN on the two above examples, so the top 20% of data would go into creating the model. The the current example would go into apply model and I would discard 70%.
I want to carry on doing this as per the below table.
Make Model Apply Model Discard
4th 30% 10% 60%
5th 40% 10% 50%
6th 50% 10% 40%
7th 60% 10% 30%
8th 70% 10% 20%
9th 80% 10% 10%
10th 90% 10% 0%
I should also note that names might occur different times sometimes just once other times over 20.
I was hoping to use the split data function with a macro to split the data. I have the percentages in my data, but I am struggling to get the figures into my split data operator.
This is my current operation, I have tried to use macros but have taken them out as it did not work and replaced them with some random ratio.
Any help would be much appreciated.
Thanks,
Oli
<process version="5.3.008">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="">
    <process expanded="true">
      <operator activated="true" class="free_memory" compatibility="5.3.008" expanded="true" height="60" name="Free Memory" width="90" x="179" y="75"/>
      <operator activated="true" class="retrieve" compatibility="5.3.008" expanded="true" height="60" name="Retrieve Names2" width="90" x="45" y="345">
        <parameter key="repository_entry" value="data/Names2"/>
      <operator activated="true" class="loop_values" compatibility="5.3.008" expanded="true" height="76" name="Loop Values" width="90" x="179" y="210">
        <parameter key="attribute" value="NAME"/>
          <operator activated="true" class="retrieve" compatibility="5.3.008" expanded="true" height="60" name="Retrieve data aw (2)" width="90" x="45" y="435">
            <parameter key="repository_entry" value="data/data aw"/>
          <operator activated="true" class="filter_examples" compatibility="5.3.008" expanded="true" height="76" name="Filter Examples (2)" width="90" x="45" y="255">
            <parameter key="condition_class" value="attribute_value_filter"/>
            <parameter key="parameter_string" value="NAME=%{loop_value}"/>
          <operator activated="true" class="free_memory" compatibility="5.3.008" expanded="true" height="60" name="Free Memory (2)" width="90" x="112" y="75"/>
          <operator activated="true" class="split_data" compatibility="5.3.008" expanded="true" height="94" name="Split Data" width="90" x="179" y="165">
            <enumeration key="partitions">
              <parameter key="ratio" value="0.2"/>
              <parameter key="ratio" value="0.8"/>
            </enumeration>
            <parameter key="sampling_type" value="linear sampling"/>
          <operator activated="true" class="k_nn" compatibility="5.3.008" expanded="true" height="76" name="k-NN (2)" width="90" x="315" y="30"/>
          <operator activated="true" class="apply_model" compatibility="5.3.008" expanded="true" height="76" name="Apply Model (2)" width="90" x="450" y="30">
          <operator activated="true" class="performance" compatibility="5.3.008" expanded="true" height="76" name="Performance (2)" width="90" x="585" y="30"/>
          <operator activated="true" class="materialize_data" compatibility="5.3.008" expanded="true" height="76" name="Materialize Data" width="90" x="514" y="210"/>
          <connect from_op="Retrieve data aw (2)" from_port="output" to_op="Filter Examples (2)" to_port="example set input"/>
          <connect from_op="Filter Examples (2)" from_port="example set output" to_op="Split Data" to_port="example set"/>
          <connect from_op="Split Data" from_port="partition 1" to_op="k-NN (2)" to_port="training set"/>
          <connect from_op="Split Data" from_port="partition 2" to_op="Apply Model (2)" to_port="unlabelled data"/>
          <connect from_op="k-NN (2)" from_port="model" to_op="Apply Model (2)" to_port="model"/>
          <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/>
          <connect from_op="Performance (2)" from_port="example set" to_op="Materialize Data" to_port="example set input"/>
          <connect from_op="Materialize Data" from_port="example set output" to_port="out 1"/>
        </process>
      <operator activated="true" class="append" compatibility="5.3.008" expanded="true" height="76" name="Append" width="90" x="380" y="165"/>
      <operator activated="true" class="write_csv" compatibility="5.3.008" expanded="true" height="76" name="Write CSV" width="90" x="447" y="300">
        <parameter key="csv_file" value="C:\Users\Oliver\Documents\Gambling\Dump\write test.CSV"/>
        <parameter key="column_separator" value=","/>
      <connect from_op="Retrieve Names2" from_port="output" to_op="Loop Values" to_port="example set"/>
      <connect from_op="Loop Values" from_port="out 1" to_op="Append" to_port="example set 1"/>
      <connect from_op="Append" from_port="merged set" to_op="Write CSV" to_port="input"/>
    </process>
</process>
1 - 1 of 11
    User: "oli"
    OP
    Just wondered if anyone had any suggestions on this, all help very much appreciated.
    Thanks,
    Oli
