<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.009"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.009" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="read_csv" compatibility="5.3.009" expanded="true" height="60" name="Read CSV" width="90" x="112" y="75"> <parameter key="csv_file" value="CSV FILE"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <parameter key="encoding" value="windows-1252"/> <list key="data_set_meta_data_information"/> </operator> <operator activated="true" class="annotations_to_data" compatibility="5.3.009" expanded="true" height="76" name="Annotations to Data" width="90" x="246" y="75"/> <operator activated="true" class="cartesian_product" compatibility="5.3.009" expanded="true" height="76" name="Cartesian" width="90" x="380" y="75"/> <connect from_op="Read CSV" from_port="output" to_op="Annotations to Data" to_port="object"/> <connect from_op="Annotations to Data" from_port="annotations" to_op="Cartesian" to_port="left"/> <connect from_op="Annotations to Data" from_port="object through" to_op="Cartesian" to_port="right"/> <connect from_op="Cartesian" from_port="join" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="90"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.009"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.009" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="loop_files" compatibility="5.3.009" expanded="true" height="76" name="Loop Files" width="90" x="45" y="30"> <parameter key="directory" value="/home/marcin/temp/loop-file"/> <process expanded="true"> <operator activated="true" class="read_csv" compatibility="5.3.009" expanded="true" height="60" name="Read CSV" width="90" x="112" y="30"> <parameter key="csv_file" value="/home/marcin/forum.csv"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <parameter key="encoding" value="windows-1252"/> <list key="data_set_meta_data_information"> <parameter key="0" value="name.true.polynominal.attribute"/> <parameter key="1" value="freq.true.integer.attribute"/> </list> </operator> <operator activated="true" class="generate_attributes" compatibility="5.3.009" expanded="true" height="76" name="Generate Attributes" width="90" x="246" y="30"> <list key="function_descriptions"> <parameter key="source" value="macro("file_path")"/> </list> </operator> <connect from_port="file object" to_op="Read CSV" to_port="file"/> <connect from_op="Read CSV" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="out 1"/> <portSpacing port="source_file object" spacing="0"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="append" compatibility="5.3.009" expanded="true" height="76" name="Append" width="90" x="246" y="30"/> <connect from_op="Loop Files" from_port="out 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="90"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
