<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.009"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.009" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.009" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="112" y="30"> <list key="attribute_values"> <parameter key="nominal_date" value=""2007-08-09 12:37:56""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_attributes" compatibility="5.3.009" expanded="true" height="76" name="Generate Attributes (2)" width="90" x="246" y="30"> <list key="function_descriptions"> <parameter key="nominal_to_data_old" value="nominal_date"/> </list> </operator> <operator activated="true" class="nominal_to_date" compatibility="5.3.009" expanded="true" height="76" name="Nominal to Date" width="90" x="380" y="30"> <parameter key="attribute_name" value="nominal_date"/> <parameter key="date_type" value="date_time"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.009" expanded="true" height="60" name="Generate Data by User Specification (2)" width="90" x="112" y="165"> <list key="attribute_values"> <parameter key="nominal_date" value=""2007-08-09 12:37:56""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_attributes" compatibility="5.3.009" expanded="true" height="76" name="Generate Attributes" width="90" x="246" y="165"> <list key="function_descriptions"> <parameter key="date" value="date_parse_custom(nominal_date, "yyyy-MM-dd HH:mm:ss", "de")"/> </list> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Generate Attributes (2)" to_port="example set input"/> <connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Nominal to Date" to_port="example set input"/> <connect from_op="Nominal to Date" from_port="example set output" to_port="result 1"/> <connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="18"/> <portSpacing port="sink_result 2" spacing="90"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
