"[Solved] Loop function"
User: "oli"
New Altair Community Member
Updated by Jocelyn
I have recently just started looking at this software and it looks really interesting. I am currently looking at the K-NN part of it.
First of all I was trying to process quite a lot of data, but have made it a lot smaller to try and get it to work, but I still have not managed it so I hope someone on here might be able to help me or point me in the right direction.
On the example I have pasted below, I bring in two names (the attribute is called NAME) where I want to predict a rating using the K-NN, it does not have any of my other data in it.
I then produce a loop, the attribute filter type is single, attribute is NAME and have used the default loop_attributes as the iteration macro.
In the loop I then retrieve the full data set that has lots of attributes in it, I link that to the filter and use parameter string NAME=%{loop_attributes} and then link to the K-NN, Apply Model and Performance. I am pretty sure it is ok from and including K-NN as if I put one of the NAME's instead of %{loop_attributes} it works. But if I leave it as NAME=%{loop_attributes} I get an error saying "The example has no examples".
I have tried quite a lot of things and looked at other peoples code, but I can not see what I am doing wrong, any help would be much appreciated.
Thanks,
Oli
<process version="5.3.008">
 <context>
   <input/>
   <output/>
   <macros/>
 </context>
 <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="">
   <process expanded="true">
     <operator activated="true" class="retrieve" compatibility="5.3.008" expanded="true" height="60" name="Retrieve Names3 (2)" width="90" x="45" y="120">
       <parameter key="repository_entry" value="data/Names3"/>
     <operator activated="true" class="loop_attributes" compatibility="5.3.008" expanded="true" height="94" name="Loop Attributes" width="90" x="179" y="30">
       <parameter key="attribute" value="NAME"/>
       <parameter key="iteration_macro" value="loop_attributes"/>
         <operator activated="true" class="retrieve" compatibility="5.3.008" expanded="true" height="60" name="Retrieve data aw" width="90" x="45" y="300">
           <parameter key="repository_entry" value="data/data aw"/>
         <operator activated="true" class="filter_examples" compatibility="5.3.008" expanded="true" height="76" name="Filter Examples" width="90" x="45" y="165">
           <parameter key="condition_class" value="attribute_value_filter"/>
           <parameter key="parameter_string" value="NAME=%{loop_attributes}"/>
         <operator activated="true" class="k_nn" compatibility="5.3.008" expanded="true" height="76" name="k-NN (3)" width="90" x="313" y="75"/>
         <operator activated="true" class="apply_model" compatibility="5.3.008" expanded="true" height="76" name="Apply Model (3)" width="90" x="447" y="75">
         <operator activated="true" class="performance" compatibility="5.3.008" expanded="true" height="76" name="Performance (3)" width="90" x="581" y="75"/>
         <connect from_op="Retrieve data aw" from_port="output" to_op="Filter Examples" to_port="example set input"/>
         <connect from_op="Filter Examples" from_port="example set output" to_op="k-NN (3)" to_port="training set"/>
         <connect from_op="k-NN (3)" from_port="model" to_op="Apply Model (3)" to_port="model"/>
         <connect from_op="k-NN (3)" from_port="exampleSet" to_op="Apply Model (3)" to_port="unlabelled data"/>
         <connect from_op="Apply Model (3)" from_port="labelled data" to_op="Performance (3)" to_port="labelled data"/>
         <connect from_op="Performance (3)" from_port="example set" to_port="result 1"/>
         <portSpacing port="sink_example set" spacing="0"/>
       </process>
     <connect from_op="Retrieve Names3 (2)" from_port="output" to_op="Loop Attributes" to_port="example set"/>
     <connect from_op="Loop Attributes" from_port="result 1" to_port="result 1"/>
   </process>
</process>
1 - 2 of 21
    User: "Andrew2"
    Hello
    If you change the loop operator to be "Loop Values" this will iterate over all the values of the NAME attribute. The "Loop Attributes" operator is looping once for the single attribute name provided (i.e. NAME) and as a consequence no examples match leading to the error you describe.
    regards
    Andrew
    User: "oli"
    OP
    Hi Andrew,
    Thank you so much for that, finally got it to work.
    Thanks,
    Oli
