<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="5.3.008" expanded="true" height="60" name="Retrieve Sonar" width="90" x="112" y="75"> <parameter key="repository_entry" value="//Samples/data/Sonar"/> </operator> <operator activated="true" class="x_validation" compatibility="5.1.002" expanded="true" height="112" name="Validation" width="90" x="246" y="75"> <description>A cross-validation evaluating a decision tree model.</description> <process expanded="true"> <operator activated="true" class="decision_tree" compatibility="5.3.008" expanded="true" height="76" name="Decision Tree" width="90" x="45" y="30"/> <connect from_port="training" to_op="Decision Tree" to_port="training set"/> <connect from_op="Decision Tree" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="5.3.008" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_binominal_classification" compatibility="5.3.008" expanded="true" height="76" name="Performance" width="90" x="231" y="30"> <parameter key="classification_error" value="true"/> <parameter key="kappa" value="true"/> <parameter key="AUC (optimistic)" value="true"/> <parameter key="AUC" value="true"/> <parameter key="AUC (pessimistic)" value="true"/> <parameter key="precision" value="true"/> <parameter key="recall" value="true"/> <parameter key="lift" value="true"/> <parameter key="fallout" value="true"/> <parameter key="f_measure" value="true"/> <parameter key="false_positive" value="true"/> <parameter key="false_negative" value="true"/> <parameter key="true_positive" value="true"/> <parameter key="true_negative" value="true"/> <parameter key="sensitivity" value="true"/> <parameter key="specificity" value="true"/> <parameter key="youden" value="true"/> <parameter key="positive_predictive_value" value="true"/> <parameter key="negative_predictive_value" value="true"/> <parameter key="psep" value="true"/> </operator> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="performance_to_data" compatibility="5.3.008" expanded="true" height="76" name="Performance to Data" width="90" x="380" y="120"/> <operator activated="true" class="store" compatibility="5.3.008" expanded="true" height="60" name="Store" width="90" x="514" y="165"> <parameter key="repository_entry" value="//Otros/performance-example-set"/> </operator> <connect from_op="Retrieve Sonar" from_port="output" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="averagable 1" to_op="Performance to Data" to_port="performance vector"/> <connect from_op="Performance to Data" from_port="example set" to_op="Store" to_port="input"/> <connect from_op="Store" from_port="through" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
