<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.008" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_nominal_data" compatibility="5.3.008" expanded="true" height="60" name="Generate Nominal Data" width="90" x="45" y="30"> <parameter key="number_of_attributes" value="1"/> <parameter key="number_of_values" value="20"/> </operator> <operator activated="true" class="subprocess" compatibility="5.3.008" expanded="true" height="76" name="Reduce values" width="90" x="246" y="30"> <process expanded="true"> <operator activated="true" class="aggregate" compatibility="5.3.008" expanded="true" height="76" name="Aggregate" width="90" x="45" y="30"> <list key="aggregation_attributes"> <parameter key="att1" value="count"/> </list> <parameter key="group_by_attributes" value="|att1"/> </operator> <operator activated="true" class="sort" compatibility="5.3.008" expanded="true" height="76" name="Sort" width="90" x="246" y="30"> <parameter key="attribute_name" value="count(att1)"/> <parameter key="sorting_direction" value="decreasing"/> </operator> <operator activated="true" class="generate_id" compatibility="5.3.008" expanded="true" height="76" name="Generate ID" width="90" x="380" y="30"/> <operator activated="true" class="join" compatibility="5.3.008" expanded="true" height="76" name="Join" width="90" x="313" y="210"> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="att1" value="att1"/> </list> </operator> <operator activated="true" class="generate_attributes" compatibility="5.3.008" expanded="true" height="76" name="Generate Attributes" width="90" x="447" y="210"> <list key="function_descriptions"> <parameter key="att1" value="if(id>10, "Other", att1)"/> </list> </operator> <operator activated="true" class="select_attributes" compatibility="5.3.008" expanded="true" height="76" name="Select Attributes" width="90" x="581" y="30"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|count(att1)|id"/> <parameter key="invert_selection" value="true"/> <parameter key="include_special_attributes" value="true"/> </operator> <connect from_port="in 1" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_op="Sort" to_port="example set input"/> <connect from_op="Aggregate" from_port="original" to_op="Join" to_port="right"/> <connect from_op="Sort" from_port="example set output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="Join" from_port="join" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <connect from_op="Generate Nominal Data" from_port="output" to_op="Reduce values" to_port="in 1"/> <connect from_op="Reduce values" from_port="out 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
