Hello everybody ,
since my registration in this forum back in November 2012 I tried everything I could to install rapidanalytics on a virtual server in order to test it for my company but the result unfortunately is always that the JBOSS server isn't startable and just freezes within the starting process and even without error message
First some server-info:Max-RAM performamce-peak: 4 GB
Always available RAM: 2 GB
OS:Ubuntu 12.04 LTS
Java:
I tried OpenJDK-Java, Oracle Java 1.7 and now Oracle Java 1.6 because I read that this is the recommended version for rapidanalytics.
java version "1.6.0_45"
Java(TM) SE Runtime Environment (build 1.6.0_45-b06)
Java HotSpot(TM) Client VM (build 20.45-b01, mixed mode, sharing)
MySQL-version (Received with the command "SELECT VERSION();" ): 5.5.31-0ubuntu0.12.04.1
The headless installation with the config file as parameter works like a charm and it finishes with the message that rapidanalytics is successfully installed.
Then I try to start the server (in this case even as root to exclude the possibility of permission problems) and unfortunately always end up with this message no matter how long I wait for the starting process to proceed:
root@vservertest:/home/nimda/rapidanalytics# sh bin/run.sh -b 0.0.0.0
JBoss Bootstrap Environment
JBOSS_HOME: /home/nimda/rapidanalytics
JAVA: /opt/Oracle_Java/jre1.6.0_45/bin/java
JAVA_OPTS: -server -Xms128m -Xmx1024m -XX:MaxPermSize=256m -Dorg.jboss.resolver.warning=true -Dsun.rmi.dgc.client.gcInterval=3600000 -Dsun.rmi.dgc.server.gcInterval=3600000 -Djava.net.preferIPv4Stack=true -Dprogram.name=run.sh -Djava.library.path=/home/nimda/rapidanalytics/bin/native/lib
CLASSPATH: /home/nimda/rapidanalytics/bin/run.jar
08:59:59,506 INFO [AbstractJBossASServerBase] Server Configuration:
JBOSS_HOME URL: file:/home/nimda/rapidanalytics/
Bootstrap: $JBOSS_HOME/server/default/conf/bootstrap.xml
Common Base: $JBOSS_HOME/common/
Common Library: $JBOSS_HOME/common/lib/
Server Name: default
Server Base: $JBOSS_HOME/server/
Server Library: $JBOSS_HOME/server/default/lib/
Server Config: $JBOSS_HOME/server/default/conf/
Server Home: $JBOSS_HOME/server/default/
Server Data: $JBOSS_HOME/server/default/data
Server Log: $JBOSS_HOME/server/default/log/
Server Temp: $JBOSS_HOME/server/default/tmp/
08:59:59,510 INFO [AbstractServer] Starting: JBossAS [6.0.0.Final "Neo"]
09:00:04,885 INFO [ServerInfo] Java version: 1.6.0_45,Sun Microsystems Inc.
09:00:04,885 INFO [ServerInfo] Java Runtime: Java(TM) SE Runtime Environment (build 1.6.0_45-b06)
09:00:04,885 INFO [ServerInfo] Java VM: Java HotSpot(TM) Server VM 20.45-b01,Sun Microsystems Inc.
09:00:04,885 INFO [ServerInfo] OS-System: Linux 2.6.32-042stab055.12,i386
09:00:04,886 INFO [ServerInfo] VM arguments: -Xms128m -Xmx1024m -XX:MaxPermSize=256m -Dorg.jboss.resolver.warning=true -Dsun.rmi.dgc.client.gcInterval=3600000 -Dsun.rmi.dgc.server.gcInterval=3600000 -Djava.net.preferIPv4Stack=true -Dprogram.name=run.sh -Djava.library.path=/home/nimda/rapidanalytics/bin/native/lib -Djava.endorsed.dirs=/home/nimda/rapidanalytics/lib/endorsed
09:00:05,067 INFO [JMXKernel] Legacy JMX core initialized
During the starting process this is my memory-usage:
Mem: 4194304k total, 145996k used, 4048308k free, 0k buffers
I absolutely don't know what I always do wrong and desperately hope that there is somebody out there knowing how to deal with this problem. Has anybody of you already heard of a situation like this before?
I intensively searched this forum but unfortunately haven't found anything for my exact situation.
In my opinion the hardware shouldn't be insufficient and there is no error message.
Thanks in advance for your effort
Stefan
