how to remove elements from generated weight list
New Altair Community Member
Updated by Jocelyn
I have a stored weight generated by operator "weight by information gain". I am planning to just keep several specific items in this weight list and remove others. How can I achieve that goal? I think i may use "filter example" operator, but could not get it work. The following is the process
<process version="5.1.011">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.1.011" expanded="true" name="Process">
<process expanded="true" height="373" width="720">
<operator activated="true" class="retrieve" compatibility="5.1.011" expanded="true" height="60" name="Retrieve" width="90" x="62" y="130">
<parameter key="repository_entry" value="svm_weight"/>
<operator activated="true" class="weights_to_data" compatibility="5.1.011" expanded="true" height="60" name="Weights to Data" width="90" x="174" y="38"/>
<operator activated="true" class="filter_examples" compatibility="5.1.011" expanded="true" height="76" name="Filter Examples" width="90" x="386" y="216">
<parameter key="condition_class" value="missing_attributes"/>
<parameter key="invert_filter" value="true"/>
<connect from_op="Retrieve" from_port="output" to_op="Weights to Data" to_port="attribute weights"/>
<connect from_op="Weights to Data" from_port="example set" to_op="Filter Examples" to_port="example set input"/>
</process>
</process>
Comments
No comments on this post.
