<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.007"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.007" expanded="true" name="Root"> <description>This learner creates a linear regression model allowing numerical predictions for the loaded data set.</description> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="5.3.007" expanded="true" height="60" name="Retrieve" width="90" x="45" y="75"> <parameter key="repository_entry" value="../../data/Polynomial"/> </operator> <operator activated="true" class="normalize" compatibility="5.3.007" expanded="true" height="94" name="Normalize" width="90" x="179" y="165"/> <operator activated="true" class="linear_regression" compatibility="5.3.007" expanded="true" height="94" name="LinearRegression" width="90" x="380" y="120"/> <operator activated="true" class="retrieve" compatibility="5.3.007" expanded="true" height="60" name="Retrieve (2)" width="90" x="179" y="300"> <parameter key="repository_entry" value="../../data/Polynomial"/> </operator> <operator activated="true" class="apply_model" compatibility="5.3.007" expanded="true" height="76" name="Apply Model" width="90" x="380" y="300"> <list key="application_parameters"/> </operator> <operator activated="true" class="apply_model" compatibility="5.3.007" expanded="true" height="76" name="Apply Model (2)" width="90" x="581" y="165"> <list key="application_parameters"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="Normalize" to_port="example set input"/> <connect from_op="Normalize" from_port="example set output" to_op="LinearRegression" to_port="training set"/> <connect from_op="Normalize" from_port="preprocessing model" to_op="Apply Model" to_port="model"/> <connect from_op="LinearRegression" from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_op="Retrieve (2)" from_port="output" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
