<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.009"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.000" expanded="true" name="Root"> <parameter key="logverbosity" value="warning"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="5.0.000" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="../../data/Iris"/> </operator> <operator activated="true" class="agglomerative_clustering" compatibility="5.0.000" expanded="true" height="76" name="AgglomerativeClustering" width="90" x="179" y="30"/> <operator activated="true" class="write" compatibility="5.3.009" expanded="true" height="60" name="Write" width="90" x="313" y="30"> <parameter key="object_file" value="/home/marcin/hierarchical.xml"/> <parameter key="output_type" value="XML"/> </operator> <operator activated="false" class="write_clustering" compatibility="5.3.009" expanded="true" height="60" name="Write Clustering" width="90" x="313" y="300"> <parameter key="cluster_model_file" value="/home/marcin/hierarc.clm"/> </operator> <operator activated="false" class="read_clustering" compatibility="5.3.009" expanded="true" height="60" name="Read Clustering" width="90" x="447" y="300"> <parameter key="cluster_model_file" value="/home/marcin/hierarc.clm"/> <parameter key="is_hierarchical_model_file" value="true"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="AgglomerativeClustering" to_port="example set"/> <connect from_op="AgglomerativeClustering" from_port="cluster model" to_op="Write" to_port="object"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
