<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.009"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.009" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="5.3.009" expanded="true" height="60" name="Retrieve Iris" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="extract_macro" compatibility="5.3.009" expanded="true" height="60" name="Extract Macro" width="90" x="179" y="30"> <parameter key="macro" value="end"/> <list key="additional_macros"/> </operator> <operator activated="true" class="generate_macro" compatibility="5.3.009" expanded="true" height="76" name="Generate Macro" width="90" x="313" y="30"> <list key="function_descriptions"> <parameter key="start" value="%{end}-25"/> </list> </operator> <operator activated="true" class="filter_example_range" compatibility="5.3.009" expanded="true" height="76" name="Filter Example Range" width="90" x="447" y="30"> <parameter key="first_example" value="%{start}"/> <parameter key="last_example" value="%{end}"/> <parameter key="invert_filter" value="true"/> </operator> <connect from_op="Retrieve Iris" from_port="output" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Generate Macro" to_port="through 1"/> <connect from_op="Generate Macro" from_port="through 1" to_op="Filter Example Range" to_port="example set input"/> <connect from_op="Filter Example Range" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
